Hi, I have got the new NanoPi 2, and followed the guide from http://wiki.friendlyarm.com/wiki/index.php/NanoPi_2 to write Debian system with DiskImager into a 16GB TF card. The system successfully booted but by using command "df" to check the disk partition, I found only approximately 3G space is allocated to the system and around 12 GB is not used. This results in "not enough space" error when I was trying to install some software. I tried re-image the card, but same result I got. Please guide what I can do.
NanoPi 2 Debian disk partition question
Get Started Essentials You Need Before play with your NanoPi2 please get the following items ready 1、NanoPi 2 2、microSD Card/TFCard: Class 10 or Above, minimum 8GB SDHC 3、microUSB power. A 5V/2A power is a must 4、HDMI monitor or LCD Make an Installation MicroSD Card Under Windows Please get the following files from here:download link to download image files: Please uncompress these files. Insert an SD card(at least 4G) to a Windows PC, run the win32diskimager utility as administrator,On the utility's main window select your SD card's drive and the image files and click on "write" to start flashing the SD card. Please insert this card to your NanoPi2 and power on (with a 5V/2A power source). If the blue LED and green LED are blinking this indicates your NanoPi2 is successfully booted.
Hi jjm, I did follow the steps you mentioned. My TF card is 16 GB, but after burning only less than 3GB used and I cannot install essential packages due to limited space in root.
Extend NanoPi 2's TF Card Section For Debian Please run the following commands on a PC host's terminal: sudo umount /dev/sdx sudo parted /dev/sdx unit % resizepart 2 100 unit MB print sudo resize2fs -f /dev/sdx2 For Android Please run the following commands on a PC host's terminal: sudo umount /dev/sdx sudo parted /dev/sdx unit % resizepart 4 100 resizepart 7 100 unit MB print sudo resize2fs -f /dev/sdx7 (Note: you need to replace "/dev/sdx" with the device name in your system)
Hi I met the same problem. My SD card capacity is 8GB, here is the console print out when I run df command: root@nanopi2:~# df -kh Filesystem Size Used Avail Use% Mounted on /dev/root 2.0G 1.6G 376M 81% / devtmpfs 405M 0 405M 0% /dev tmpfs 406M 0 406M 0% /dev/shm tmpfs 406M 6.1M 399M 2% /run tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs 406M 0 406M 0% /sys/fs/cgroup tmpfs 82M 4.0K 82M 1% /run/user/1000 tmpfs 82M 0 82M 0% /run/user/0 /dev/mmcblk0p1 63M 16M 48M 26% /media/fa/boot1 Only 2GB for root, I've also checked available partition : root@nanopi2:~# ls /dev/ | grep mmc mmcblk0 mmcblk0p1 mmcblk0p2 Try to mount /dev/mmcblk0p2 but I get the same folder as Debian root file system root@nanopi2:~# mount /dev/mmcblk0p2 mount_point/ root@nanopi2:~# ls mount_point/ bin dev home lost+found mnt proc run srv tmp var boot etc lib media opt root sbin sys usr Not easy to understand. I've use win32diskimager.exe to creat bootable microSD card, somethings are wrong here.
Im having the same problem... Could it be the format of the original SD card ? I may have formatted as FAT32... and not extFat before copying the image on... that could explain why its just under 4Gb, and not the whole SD card capacity... I'm going to try... will report back...
Work only this command >sudo resize2fs -f /dev/mmcblk0p2 increase free size up to 47% pi@nanopi2:~$ sudo df -kh Filesystem Size Used Avail Use% Mounted on /dev/root 3.1G 1.7G 1.5G 53% / devtmpfs 405M 0 405M 0% /dev tmpfs 406M 0 406M 0% /dev/shm tmpfs 406M 12M 394M 3% /run tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs 406M 0 406M 0% /sys/fs/cgroup tmpfs 82M 4.0K 82M 1% /run/user/1000 /dev/mmcblk0p1 63M 16M 48M 26% /media/fa/boot1 tmpfs 82M 4.0K 82M 1% /run/user/1001 pi@nanopi2:~$
I knew how to make as simple as possible. 2 pertition (/dev/mmcblk0p2) cannot be changed - because it was loaded and can't be unmounted / So it is necessary to boot from another SD card (!!!) 1) I Made a second SD card - as a clone bootable SD ( by win2image.exe ) and put it in the primary slot. Original SD card - put into secondary slot 2) Reboot 2) Set the tool gparted. (sudo apt-get install gparted) 3) Run gparted 3) Chose the 2nd drive and 2nd partition, then success unmount /dev/mmcblk0p2 4) Check /dev/mmcblk0p2 of the error and resize to nessesary size 5) Exit gparted 6) Shutdown 7) Put a original card from the 2nd slot back to first slot 8) Starting without any error's and warning's Bingo ! Best regards, Serge
I have the NanoPi M1 and this has exactly the same issue. It has only 2GB of available space when the SD is 8GB. I followed your installation instructions. You should note that in the case of the Raspberry Pi, they automatically resize the partition on first use of the card. It would make sense for you to do the same and save customers this problem. The instructions above do not work and I don't have a second "slot" to put the card into. So - for Debian and the M1 - how do I resize the partition to fill the available Space - I cannot even do apt-get upgrade as there is no room? Pete.
On the NanoPC T2 you gave similar advice for Android to that above. It simply does not work. I checked that SDA exists - it does. I have a 64GB SD. 1. sudo unount /dev/sda This reports that /dev/sda is not mounted 2. sudo parted /dev/sda unit % resizepart 4 100 resizepart 7 100 unit MB print Parted objects to invalid token:100 then says Yes/No. I select Y. If then says End? [6.111$]? I put in 100% It then says "Information: You may need to update /etc/fstab 3. sudo resize2fs -f /dev/sda7 The unit says the filesystem is already 62448 (4k) blocks long. Nothing to do. And that's it - I put the SD back into the PCT3 and absolutely nothing has changed!!!! This is starting to get tedious - Android with only 4Gig is utterly useless. What is the correct procedure to expand to make use of the rest of my 64GB SD please?
Hello all, Now you can use the latest image which has added resize SD card directly when you boot the board first time,you donot need resize by yourself.
