Hi, have anyone notice the temperature of the nanopi 2 cpu. It's getting extremely hot when streaming videos. The system reboots automatically after a while. Don't know what's the normal operating temp for this chip.
Nanopi 2 cpu temperature
NanoPi 2 was next on my purchase list. I have two NanoPC-T1s and one would overheat and shutdown just running a Ubuntu desktop, ie no streaming video. It recovered a few times then finally said, "I quit". Before you lose yours maybe try a stick-on CPU heatsink and make sure you have a good airflow around the CPU. I have read comments that as these parts are used in mobile devices so they should be able to survive, but maybe people are NOT streaming videos like you are! See what Odroid do on the their product. http://www.hardkernel.com/main/main.php
Thx dave, I actually had a small heatsink on it already. Unfortunately, the temp is still over 60C when CPU/GPU is running on full. I guess a fan is the only solution left. The nanopi 2 board is very powerful. The only problem I have with it is its board design. The cpu chip is slightly lower than the surroundings which makes it hard to add big headsinks. Maybe in the next version, friendlyarm will have better designs. Cheers,
A fan, even on a small (stick-on) heatsink should make a significant difference. Does the unit still shutdown with the small heatsink?
Datasheet page 43-3 Operating ambient temp TBD Went back to the S3C2440 used in the mini2440 Operating temperature TOPR Industrial –40 to 85C However, that doesn't tell you anything about the temperature on the chip. Some high-end processors have on-chip temperature measurement and I thought the ability to turn down clock speed to reduce power consumption. Couldn't see any mention of thermal management in the datasheet. I know that would probably NOT make for a good video streaming experience! You say space is tight. How about a small piece of copper or aluminium plate to act as a spacer to a suitable heatsink that you could mount a fan on? Also, thermal compound or thermal pads between the various interfaces.
Thx Dave. Great suggestion. I'm working on an metal enclosure for the nanopi. I'll use the enclosure itself as the heatsink. I guess that shall be enough.
To use the enclosure, as a heatsink, you will need a good thermal path between the CPU and the case and the case will need to effectively get rid of the heat. A challenging thermal problem. ... a bit laggy ... maybe the throttling is working.
hello,
There are the results of nanopi 2 high and low temperature test (have a
mouse and HDMI connected to):
--low temperature –40°C (24 hours) normal. NanoPi 2 can normal work in
low temperature.
--high temperature 80°C (48 hours) normal ,90°C (48 hours) normal. NanoPi 2
can normal work in high temperature.
