Hi I want to try some GPIO add on boards from the Raspberry Pi, but I can't find any documentation on using the NanoPi 2 GPIO? Can you share install/setup and usage instructions? Thanks
How to install and use GPIO on NanoPi 2?
I see the i2c (/dev/i2c-0/1) and SPI (/dev/spidev0.0) buses but nothing for PWM (no /dev/pwm). Control of the GPIOs (via SYSFS) should be accessible through '/sys/class/gpio' but it would be nice if someone more knowledgeable could chime in on the proper way to access the GPIOs and PWM via built-in Linux drivers and/or SYSFS.
If you want to use NanoPi 2 physical GPIO pins , you can refer to the following steps: # cd /sys/class/gpio # for i in gpiochip* ; do echo `cat $i/label`: `cat $i/base` ; done nxp-gpio.0:0 nxp-gpio.4:128 nxp-gpio.5:160 nxp-gpio.1:32 nxp-gpio.2:64 nxp-gpio.3:96 Actually the gpio.0 express GPIOA, gpio.1 express GPIOB... For example , if you want to use GPIOB30 of NanoPi 2 , we can use the GPIO such as :64 + 30 = 94.
hi @jjm, do you have any simple example showing how to read/write GPIO via built-int linux drivers? I read the code from https://github.com/friendlyarm/matrix/blob/nanopi/lib/gpio.c and there is a MACRO defined as below: #define GPIO_FILENAME_DEFINE(pin,field) char fileName[255] = {0}; \ sprintf(fileName, "/sys/devices/virtual/gpio/gpio%d/%s", pin, field); but I checked the file system of Nanopi2 and could not find any GPIO files under /sys/devices/virtual/, I guess this is because the GPIO device is not "booted" but don't know how.
Hi you can refer to our Matrix components' wiki sites: Here is one : http://wiki.friendlyarm.com/wiki/index.php/Matrix_-_Ball_Rolling_Switch I would encourage you to post on www.friendlyarm.com/forum which we visit more often
Much of this is just WAY too complicated. Isn't there a module to help run the GPIO pins? These boards are in the same marketplace as Raspberry Pi and there is a TON of documentation - and several drivers to run simple I/O (on/off), PWM, I2c etc. We need similar for these boards. I have a FriendlyArm NanoPC 2 running Jessie and Node-Red, I've only been able to get 1 of the 4 UARTS running and can find nothing in the way of examples of which ports are available and how to access them. A simple guide with examples would help.
Hi you can refer the Matrix components' wiki sites , and there are much more course and code you can refer : http://wiki.friendlyarm.com/wiki/index.php/Main_Page#Matrix
I am trying to run matrix gpio-out on nano pi s2 to blink led but getting these error? what went wrong please reply? fa@NanoPi2:~/matrix$ matrix-gpio_out Hardware:NANOPI2 Revision:0002 BoardType:-1 FAHW-Lib: Fail to initPinGPIO FAHW-Lib: Fail to initPwmGPIO Fail to init board fa@NanoPi2:~/matrix$
