Hi every one.
I have mini2440 and GSM modem that they connected to each other with USB
serial port (ttyUSB0). this is my code in c++ to send AT:
#include <QCoreApplication>
#include <stdio.h> /* Standard input/output definitions */
#include <string.h> /* String function definitions */
#include <unistd.h> /* UNIX standard function definitions */
#include <fcntl.h> /* File control definitions */
#include <errno.h> /* Error number definitions */
#include <termios.h> /* POSIX terminal control definitions */
#include <string> /*To use string type*/
#include <iostream>
#include <string>
using namespace std;
// Definations
int fd; /* File descriptor for the port */
string wr;
int rd;
char buffer[100]; /* Input buffer */
int openport(void);
void closeport(void);
void configport(void);
string WriteRead(void);
int main(int argc, char *argv[])
QCoreApplication a(argc, argv);
openport();
if(fd>-1)
configport();
string str=WriteRead();
qDebug(str.c_str());
return a.exec();
int openport(void)
fd=open("/dev/ttyUSB0",O_RDWR|O_NOCTTY|O_NDELAY);
if (fd==-1)
perror("open_port: unable to open port /dev/ttyUSB0\n");
return -1;
else
printf("open_port: succesfully open port /dev/ttyUSB0\n");
fcntl(fd,F_SETFL,0);
return 1;
close(fd);
struct termios options;
tcgetattr(fd,&options);
cfsetispeed(&options,B9600);
cfsetospeed(&options,B9600);
options.c_cflag |= (CLOCAL | CREAD);
options.c_cflag &= ~CSIZE;
options.c_cflag |= CS8;
options.c_cflag &= ~ PARENB;
options.c_cflag &= ~CSTOPB;
options.c_iflag &= ~(IXON|IXOFF|IXANY);
tcsetattr(fd,TCSANOW,&options);
char buffer[255]; /* Input buffer */
char *bufptr; /* Current char in buffer */
int nbytes; /* Number of bytes read */
int tries; /* Number of tries so far */
for (tries = 0; tries < 3; tries ++)
if (write(fd, "AT\r", 3) < 3)// send an AT command followed by a CR
continue;
// read characters into our string buffer until we get a CR or NL
bufptr = buffer;
while ((nbytes = read(fd, bufptr, buffer + sizeof(buffer) - bufptr
- 1)) > 0)
bufptr += nbytes;
if (bufptr[-1] == '\n' || bufptr[-1] == '\r')
break;
/* nul terminate the string and see if we got an OK response */
*bufptr = '\0';
string s(buffer);
if (s.find("OK"))
return s;
else
return "not answer";
but after send AT i say if find "OK" set the buffer to string s. then write
string s in output. but it just write AT. there is no OK
send AT command from mini2440
Hi
I get my answer:
my problem is in modem config . this is my new config:
struct termios tty;
struct termios tty_old;
memset (&tty, 0, sizeof tty);
/* Error Handling */
if ( tcgetattr ( fd, &tty ) != 0 ) {
std::cout << "Error " << errno << " from tcgetattr: " <<
strerror(errno) << std::endl;
/* Save old tty parameters */
tty_old = tty;
/* Set Baud Rate */
cfsetospeed (&tty, (speed_t)B9600);
cfsetispeed (&tty, (speed_t)B9600);
/* Setting other Port Stuff */
tty.c_cflag &= ~PARENB; // Make 8n1
tty.c_cflag &= ~CSTOPB;
tty.c_cflag &= ~CSIZE;
tty.c_cflag |= CS8;
tty.c_cflag &= ~CRTSCTS; // no flow control
tty.c_cc[VMIN] =1;// 0; // read doesn't block
tty.c_cc[VTIME] = 10;// 2 but befor it 5; // 0.5
seconds read timeout
tty.c_cflag |= CREAD | CLOCAL; // turn on READ & ignore
ctrl lines
/* Make raw */
cfmakeraw(&tty);
/* Flush Port, then applies attributes */
tcflush( fd, TCIFLUSH );
if ( tcsetattr ( fd, TCSANOW, &tty ) != 0) {
std::cout << "Error " << errno << " from tcsetattr" << std::endl;
my problem is solved
