hello, can anyone tell me how to cross compile of qt 4.8.5 for friendlyarm tiny 6410??
Try this from the official QT web site: 1. http://doc.qt.io/qt-4.8/qt-embedded-crosscompiling.html Here are couple of links I found helpful. Although they are for the Qt 4.6.3 on mini2440, just make the relevant changes for the tiny 6410 using the QT 4.8.5 sources. 2. https://suchakra.wordpress.com/2011/05/17/qt-on-mini2440/ 3. https://suchakra.wordpress.com/tag/qt/ 4. https://suchakra.wordpress.com/2011/05/30/developing-qt-apps/ Good luck, Gautam
1. tslib compilation $cd /usr/local $git clone http://github.com/kergoth/tslib.git $export PATH=/usr/local/arm/4.3.2/bin:$PATH $export CROSS_COMPILE=arm-none-linux-gnueabi- $export CC=${CROSS_COMPILE}gcc $export CFLAGS=-march=armv4t $export CXX=${CROSS_COMPILE}"g++" $export AR=${CROSS_COMPILE}"ar" $export AS=${CROSS_COMPILE}"as" $export RANLIB=${CROSS_COMPILE}"ranlib" $export LD=${CROSS_COMPILE}"ld" $export STRIP=${CROSS_COMPILE}"strip" $export ac_cv_func_malloc_0_nonnull=yes $cd /usr/local/tslib $./autogen-clean.sh $./autogen.sh $./configure --host=arm-linux --prefix=/home/tslib --enable-shared=yes --enable-static=yes $make $make install i followed this steps for first tslib installation but when i checked file libts-1.0.so.0.0.0 in lib file then i got following output==> libts-1.0.so.0.0.0: ELF 32-bit LSB shared object, "Intel 80386", version 1 (SYSV), dynamically linked, BuildID[sha1]=0xd113e8e6a6562ca3bd32f286ed9611919adc9a44, not stripped i want arm instead of that Intel 80386??
Using built-in specs. COLLECT_GCC=arm-linux-gcc COLLECT_LTO_WRAPPER=/home/sachin/Documents/ARM_CROSS_COMPILER/fsl-linaro-toolcha in/bin/../libexec/gcc/arm-fsl-linux-gnueabi/4.6.2/lto-wrapper Target: arm-fsl-linux-gnueabi Configured with: /work/build/.build/src/gcc-linaro-4.6-2011.06-0/configure --build=i686-build_pc-linux-gnu --host=i686-build_pc-linux-gnu --target=arm-fsl-linux-gnueabi --prefix=/work/fsl-linaro-toolchain-2.13 --with-sysroot=/work/fsl-linaro-toolchain-2.13/arm-fsl-linux-gnueabi/multi-libs --enable-languages=c,c++ --with-pkgversion='Freescale MAD -- Linaro 2011.07 -- Built at 2011/08/10 09:20' --enable-__cxa_atexit --disable-libmudflap --disable-libgomp --disable-libssp --with-gmp=/work/build/.build/arm-fsl-linux-gnueabi/build/static --with-mpfr=/work/build/.build/arm-fsl-linux-gnueabi/build/static --with-mpc=/work/build/.build/arm-fsl-linux-gnueabi/build/static --with-ppl=/work/build/.build/arm-fsl-linux-gnueabi/build/static --with-cloog=/work/build/.build/arm-fsl-linux-gnueabi/build/static --with-libelf=/work/build/.build/arm-fsl-linux-gnueabi/build/static --with-host-libstdcxx='-static-libgcc -Wl,-Bstatic,-lstdc++,-Bdynamic -lm -L/work/build/.build/arm-fsl-linux-gnueabi/build/static/lib -lpwl' --enable-threads=posix --enable-target-optspace --enable-plugin --enable-multilib --with-local-prefix=/work/fsl-linaro-toolchain-2.13/arm-fsl-linux-gnueabi/multi- libs --disable-nls --enable-c99 --enable-long-long --with-system-zlib Thread model: posix gcc version 4.6.2 20110630 (prerelease) (Freescale MAD -- Linaro 2011.07 -- Built at 2011/08/10 09:20)
./configure --host=arm-linux --prefix=/home/tslib --enable-shared=yes --enable-static=yes i am executing this command and search for below so foolowing term not change to arm checking build system type... i686-pc-linux-gnu checking host system type... arm-unknown-linux-gnu
Sachin, What is the output of: $arm-none-linux-gnueabi-gcc -v (P.S. Your CROSS_COMPILE env variable is set to "arm-none-linux-gnueabi-" not "arm-linux-") Also check the generated Makefile for occurrences of "i686-pc-linux-gnu" see if they seem appropriate.
output for arm-none-linux-gnueabi-gcc -v ===>> Using built-in specs. COLLECT_GCC=arm-linux-gcc COLLECT_LTO_WRAPPER=/home/sachin/Documents/ARM_CROSS_COMPILER/fsl-linaro-toolcha in/bin/../libexec/gcc/arm-fsl-linux-gnueabi/4.6.2/lto-wrapper Target: arm-fsl-linux-gnueabi Configured with: /work/build/.build/src/gcc-linaro-4.6-2011.06-0/configure --build=i686-build_pc-linux-gnu --host=i686-build_pc-linux-gnu --target=arm-fsl-linux-gnueabi --prefix=/work/fsl-linaro-toolchain-2.13 --with-sysroot=/work/fsl-linaro-toolchain-2.13/arm-fsl-linux-gnueabi/multi-libs --enable-languages=c,c++ --with-pkgversion='Freescale MAD -- Linaro 2011.07 -- Built at 2011/08/10 09:20' --enable-__cxa_atexit --disable-libmudflap --disable-libgomp --disable-libssp --with-gmp=/work/build/.build/arm-fsl-linux-gnueabi/build/static --with-mpfr=/work/build/.build/arm-fsl-linux-gnueabi/build/static --with-mpc=/work/build/.build/arm-fsl-linux-gnueabi/build/static --with-ppl=/work/build/.build/arm-fsl-linux-gnueabi/build/static --with-cloog=/work/build/.build/arm-fsl-linux-gnueabi/build/static --with-libelf=/work/build/.build/arm-fsl-linux-gnueabi/build/static --with-host-libstdcxx='-static-libgcc -Wl,-Bstatic,-lstdc++,-Bdynamic -lm -L/work/build/.build/arm-fsl-linux-gnueabi/build/static/lib -lpwl' --enable-threads=posix --enable-target-optspace --enable-plugin --enable-multilib --with-local-prefix=/work/fsl-linaro-toolchain-2.13/arm-fsl-linux-gnueabi/multi- libs --disable-nls --enable-c99 --enable-long-long --with-system-zlib Thread model: posix gcc version 4.6.2 20110630 (prerelease) (Freescale MAD -- Linaro 2011.07 -- Built at 2011/08/10 09:20)
i am follow these steps==> #!/bin/sh #export CROSS_COMPILE=/home/sachin/Documents/ARM_CROSS_COMPILER/fsl-linaro-toolchain/bin /arm-fsl-linux-gnueabi- export CC=/home/sachin/Documents/ARM_CROSS_COMPILER/fsl-linaro-toolchain/bin/arm-fsl-li nux-gnueabi-gcc export CFLAGS=-march=armv4t export CXX=/home/sachin/Documents/ARM_CROSS_COMPILER/fsl-linaro-toolchain/bin/arm-fsl-l inux-gnueabi-g++ export AR=/home/sachin/Documents/ARM_CROSS_COMPILER/fsl-linaro-toolchain/bin/arm-fsl-li nux-gnueabi-ar export AS=/home/sachin/Documents/ARM_CROSS_COMPILER/fsl-linaro-toolchain/bin/arm-fsl-li nux-gnueabi-as export RANLIB=/home/sachin/Documents/ARM_CROSS_COMPILER/fsl-linaro-toolchain/bin/arm-fs l-linux-gnueabi-ranlib export LD=/home/sachin/Documents/ARM_CROSS_COMPILER/fsl-linaro-toolchain/bin/arm-fsl-li nux-gnueabi-ld export STRIP=/home/sachin/Documents/ARM_CROSS_COMPILER/fsl-linaro-toolchain/bin/arm-fsl -linux-gnueabi-strip export ac_cv_func_malloc_0_nonnull=yes sudo ./autogen-clean.sh ./autogen.sh sudo ./configure --host=arm-fsl-linux-gnueabi --prefix=/home/tslib --enable-shared=yes --enable-static=yes sudo make sudo make install
It has been a few years since I did this stuff from scratch but do you need either: --build xyz or --target xyz on the ./configure command
--host=arm-linux-gnu --build-i386-linux-gnu appears in most of my compile scripts. I think this is for building on a PC running Ubuntu.
hello i have try theses but not worked.... this is single script file for tslib compilation "tslib.sh" ==> export CROSS_COMPILE=/home/sachin/opt/FriendlyARM/toolschain/4.5.1/bin/arm-fsl-linux-gn ueabi- export CC=${CROSS_COMPILE}"gcc" export CFLAGS=-march=armv7-a export CXX=${CROSS_COMPILE}"g++" export AR=${CROSS_COMPILE}"ar" export AS=${CROSS_COMPILE}"as" export RANLIB=${CROSS_COMPILE}"ranlib" export LD=${CROSS_COMPILE}"ld" export STRIP=${CROSS_COMPILE}"strip" export ac_cv_func_malloc_0_nonnull=yes sudo ./autogen-clean.sh sudo ./autogen.sh sudo ./configure --host=arm-fsl-linux-gnueabi --build=i386-linux-gnu --prefix=/home/tslib --enable-shared=yes --enable-static=yes sudo make sudo make install
Are there any error messages? I would comment out the last two lines and just run the ./configure line and see if that is successful. Then sudo make and lastly sudo make install.
above ./configure command is executed succesfully without any error but when i checked cd /home/tslib/lib in that libts file....and i run the following command to check cross compiler is created or not... file libts it shows only "intel" and i want "arm" instead of these.
sachin@Atishay:~/Documents/tslib$ sudo ./configure --host=arm-fsl-linux-gnueabi --prefix=/home/tslib --enable-shared=yes --enable-static=yes [sudo] password for sachin: configure: WARNING: if you wanted to set the --build type, don't use --host. If a cross compiler is detected then cross compile mode will be used checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking for arm-fsl-linux-gnueabi-strip... no checking for strip... strip checking for a thread-safe mkdir -p... /bin/mkdir -p checking for gawk... no checking for mawk... mawk checking whether make sets $(MAKE)... yes checking for arm-fsl-linux-gnueabi-gcc... no checking for gcc... gcc checking whether the C compiler works... yes checking for C compiler default output file name... a.out checking for suffix of executables... checking whether we are cross compiling... no checking for suffix of object files... o checking whether we are using the GNU C compiler... yes checking whether gcc accepts -g... yes checking for gcc option to accept ISO C89... none needed checking for style of include used by make... GNU checking dependency style of gcc... gcc3 checking how to run the C preprocessor... gcc -E checking whether the C compiler supports -fvisibility=hidden... yes checking whether to use -fvisibility=hidden... yes checking whether ln -s works... yes checking whether make sets $(MAKE)... (cached) yes checking build system type... i686-pc-linux-gnu checking host system type... arm-fsl-linux-gnueabi checking how to print strings... printf checking for a sed that does not truncate output... /bin/sed checking for grep that handles long lines and -e... /bin/grep checking for egrep... /bin/grep -E checking for fgrep... /bin/grep -F checking for ld used by gcc... /usr/bin/ld checking if the linker (/usr/bin/ld) is GNU ld... yes checking for BSD- or MS-compatible name lister (nm)... no checking for arm-fsl-linux-gnueabi-dumpbin... no checking for arm-fsl-linux-gnueabi-link... no checking for dumpbin... no checking for link... link -dump checking the name lister (nm) interface... BSD nm checking the maximum length of command line arguments... 1572864 checking whether the shell understands some XSI constructs... yes checking whether the shell understands "+="... yes checking how to convert i686-pc-linux-gnu file names to arm-fsl-linux-gnueabi format... func_convert_file_noop checking how to convert i686-pc-linux-gnu file names to toolchain format... func_convert_file_noop checking for /usr/bin/ld option to reload object files... -r checking for arm-fsl-linux-gnueabi-objdump... no checking for objdump... objdump checking how to recognize dependent libraries... pass_all checking for arm-fsl-linux-gnueabi-dlltool... no checking for dlltool... no checking how to associate runtime and link libraries... printf %s\n checking for arm-fsl-linux-gnueabi-ar... no checking for ar... ar checking for archiver @FILE support... @ checking for arm-fsl-linux-gnueabi-strip... strip checking for arm-fsl-linux-gnueabi-ranlib... no checking for ranlib... ranlib checking command to parse nm output from gcc object... ok checking for sysroot... no checking for arm-fsl-linux-gnueabi-mt... no checking for mt... mt checking if mt is a manifest tool... no checking for ANSI C header files... yes checking for sys/types.h... yes checking for sys/stat.h... yes checking for stdlib.h... yes checking for string.h... yes checking for memory.h... yes checking for strings.h... yes checking for inttypes.h... yes checking for stdint.h... yes checking for unistd.h... yes checking for dlfcn.h... yes checking for objdir... .libs checking if gcc supports -fno-rtti -fno-exceptions... no checking for gcc option to produce PIC... -fPIC -DPIC checking if gcc PIC flag -fPIC -DPIC works... yes checking if gcc static flag -static works... yes checking if gcc supports -c -o file.o... yes checking if gcc supports -c -o file.o... (cached) yes checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes checking whether -lc should be explicitly linked in... no checking dynamic linker characteristics... GNU/Linux ld.so checking how to hardcode library paths into programs... immediate checking for shl_load... no checking for shl_load in -ldld... no checking for dlopen... no checking for dlopen in -ldl... yes checking whether a program can dlopen itself... yes checking whether a statically linked program can dlopen itself... no checking whether stripping libraries is possible... yes checking if libtool supports shared libraries... yes checking whether to build shared libraries... yes checking whether to build static libraries... yes checking for dlopen in -ldl... (cached) yes checking for size_t... yes checking for working alloca.h... yes checking for alloca... yes checking for ANSI C header files... (cached) yes checking fcntl.h usability... yes checking fcntl.h presence... yes checking for fcntl.h... yes checking limits.h usability... yes checking limits.h presence... yes checking for limits.h... yes checking for stdlib.h... (cached) yes checking for string.h... (cached) yes checking sys/ioctl.h usability... yes checking sys/ioctl.h presence... yes checking for sys/ioctl.h... yes checking sys/time.h usability... yes checking sys/time.h presence... yes checking for sys/time.h... yes checking for unistd.h... (cached) yes checking for an ANSI C-conforming const... yes checking for inline... inline checking for size_t... (cached) yes checking whether time.h and sys/time.h may both be included... yes checking whether gcc needs -traditional... no checking for stdlib.h... (cached) yes checking for unistd.h... (cached) yes checking for sys/param.h... yes checking for getpagesize... yes checking for working mmap... yes checking sys/select.h usability... yes checking sys/select.h presence... yes checking for sys/select.h... yes checking sys/socket.h usability... yes checking sys/socket.h presence... yes checking for sys/socket.h... yes checking types of arguments for select... int,fd_set *,struct timeval * checking return type of signal handlers... void checking whether lstat correctly handles trailing slash... yes checking whether stat accepts an empty string... no checking for vprintf... yes checking for _doprnt... no checking for gettimeofday... yes checking for memmove... yes checking for memset... yes checking for munmap... yes checking for select... yes checking for strcasecmp... yes checking for strchr... yes checking for strdup... yes checking for strtoul... yes checking whether linear module is requested... yes checking whether dejitter module is requested... yes checking whether linear-h2200 module is requested... yes checking whether variance module is requested... yes checking whether pthres module is requested... yes checking whether ucb1x00 module is requested... yes checking whether cy8mrln-palmpre module is requested... no checking whether corgi module is requested... yes checking whether collie module is requested... yes checking whether h3600 module is requested... yes checking whether mk712 module is requested... yes checking whether arctic2 module is requested... yes checking whether tatung module is requested... yes checking whether dmc module is requested... yes checking whether input module is requested... yes checking whether touchkit module is requested... yes checking whether galax module is requested... yes checking where to place modules... ${libdir}/ts checking whether to enable debugging... no configure: creating ./config.status config.status: creating Makefile config.status: creating etc/Makefile config.status: creating plugins/Makefile config.status: creating src/Makefile config.status: creating tests/Makefile config.status: creating tslib.pc config.status: creating tslib-1.0.pc config.status: creating config.h config.status: config.h is unchanged config.status: executing depfiles commands config.status: executing libtool commands ranlib,cc,gcc,ld etc value are not taking...i m confused with above output
Have you read through this tutorial? http://mini2440vietnam.blogspot.co.nz/2011/04/upgrade-qt462-in-mini2440.... Does readelf -a <filename> give the same "intel" result as file libts? > If a cross compiler is detected then cross compile mode will be used and > checking for arm-fsl-linux-gnueabi-gcc... no Seems to be suggesting that the correct toolchain is not found.
yes i have followed same site for tslib installation and for checking libts file give the same result "intel" do have any site for downloading proper toochain?
I checked the downloads page under 6410 and don't see a toolchain. Try the Downloads Server. Think they are having a problems on the site, at the moment
@davef cant solved issue....how i install new toolchain for ARM for this cross compiling rather than old one...i think toolchain is the issue here...
********************************************* INSTALLATION PROCEDURE FOR tslib LIBRARY ==> ********************************************* ->first downloaded from the Internet tslib-1.0.tar.gz ->Extract the tar xvzf tslib-1.0.tar.gz ->then follow the script tslib.sh and check the variable path and all ->uncomment the first line in tslib/etc/ts_conf file # Uncomment if you wish to use the linux input layer event interface module_raw input ****************************************************** ERROR AND SOLUTION DURING INSTALLATION OF TSLIB ===> ****************************************************** 1. ./autogen.sh: 4: ./autogen.sh: autoreconf: not found sol : sudo apt-get install autoconf 2. autoreconf: failed to run libtoolize: No such file or directory sol : sudo apt-get install build-essential libtool 3. undefined reference to `rpl_malloc ' sol :configure, add option ac_cv_func_malloc_0_nonnull = yes 2. Couldnt open tslib config file sol :ts.conf path is not set correctly; 3. No raw modules loaded.ts_config: No such file or directory sol :Enter the module directory is set correctly set ts directory Or the tslib library does not edit the input module In the tslib library source tslib / etc / ts.conf remove module_raw input before # and spaces removed, and then run the compiled copy operation; 4. / Usr/include/bits/fcntl2.h: 51:24: error: call to '__open_missing_mode' declared with attribute error: open with O_CREAT in second argument needs 3 arguments In function 'open', inlined from 'main' at ts_calibrate.c: 229:11: / Usr/include/bits/fcntl2.h: 51:24: error: call to '__open_missing_mode' declared with attri sol : / / source file / / if ((calfile = the getenv (TSLIB_CALIBFILE "))! = NULL) {/ / cal_fd = open (calfile, O_CREAT | O_RDWR); / /} else {/ / cal_fd = open ( "/ etc / pointercal", O_CREAT | O_RDWR); / /} / / need to change the following form if ((calfile = getenv ("TSLIB_CALIBFILE"))! = NULL) {cal_fd = open (calfile, O_CREAT | O_RDWR, 0777 );} else {cal_fd = open ("/ etc /pointercal", O_CREAT | O_RDWR, 0777);} 5. Can't exec "libtoolize": No such file or directory at / usr / bin / autoreconf line 190.Use of uninitialized value $ libtoolize in pattern match (m / /) at / usr / bin / autoreconf line Sol : installed in Ubuntu libtool.deb or update with the command: apt-get install libtool 6 Can't exec "aclocal": No such file or directory at / usr/share/autoconf/Autom4te/FileUtils.pm line 290 Sol : apt-get install automake tslib.sh file ==> #!/bin/sh export CROSS_COMPILE=/home/surekha/Cross_compiler/fsl-linaro-toolchain/bin/arm-fsl-linu x-gnueabi- export CC=${CROSS_COMPILE}"gcc" export CFLAGS=-march=armv7-a export CXX=${CROSS_COMPILE}"g++" export AR=${CROSS_COMPILE}"ar" export AS=${CROSS_COMPILE}"as" export RANLIB=/home/surekha/Cross_compiler/fsl-linaro-toolchain/bin/arm-fsl-linux-gnuea bi-ranlib export LD=${CROSS_COMPILE}"ld" export STRIP=${CROSS_COMPILE}"strip" export ac_cv_func_malloc_0_nonnull=yes sudo ./autogen-clean.sh ./autogen.sh sudo ./configure CC=/home/surekha/Cross_compiler/fsl-linaro-toolchain/bin/arm-fsl-linux-gnueabi-g cc --host=arm-unknown-linux --build=i386-linux --prefix=/usr/local/tslib ac_cv_func_malloc_0_nonnull=yes sudo make sudo make install i have followed above all steps for tslib-1.0 compilation and succeed.
