Nanopi WIFI settings
Naveen
I am unable to setup wifi with NANO pi .
I  have used the below as per your literature:
auto lo
iface lo inet loopback
auto wlan0
iface wlan0 inet dhcp
wpa-driver wext
wpa-ssid <MYSSID>
wpa-ap-scan 1
wpa-proto RSN
wpa-pairwise CCMP
wpa-group CCMP
wpa-key-mgmt WPA-PSK
wpa-psk <MYWIFI PASSWORD>
Still unable to connect to our local Wi-Fi. I have changed the security
settings to WPA2-PSK in the above to suit our Router which is configured
with WPA2-PSK security settings. The Access point SSID and Password are
checked several times.
Does this module work only for WPA-PSK ? or any other security schemes ?
I am to scan and see the wifi networks, but not able to connect. any help
is appreciated
Naveen
This is the process I will be using when my NanoPi arrives.
https://github.com/forrestbao/NanoPi/wiki/FriendlyARM-images
After a quick look through I don't see anything different, but do post back
if you sort it.
Good luck,
Dave
http://wiki.friendlyarm.com/wiki/index.php/NanoPi
Looks like this document was just updated with some WiFi information.
naveen
Worked when I disable AP mode.
Naveen
Arash
I can not see my nanopi WiFi AP. I use command 'turn-wifi-into-apmode yes'
but nothing changed. Is there any other initialization for WiFi?
Thanks,
Arash
Arash
I think problem is because of driver. Here is output of execution of
hostapd manually:
root@nanopi:~# hostapd /etc/hostapd/hostapd.conf
Configuration file: /etc/hostapd/hostapd.conf
nl80211: Could not configure driver mode
nl80211 driver initialization failed.
hostapd_free_hapd_data: Interface wlan0 wasn't started
How can I fix this?
Regard,
Arash
Kit
how to disable the AP mode ??? followed the wiki link but bot much success
... please help which link you were following @Naveen
Phil_in_China
You could try:
turn-wifi-into-apmode no
Kit
Nope .. nothing happened ...i want to run internet on my nanoPi .. and cant
configure wifi settings ?????
I also set a static address in wlan0 and I get:
Using interface wlano with hwaddr 04:e6:76:71:49:77 and ssid
"nanopi-wifiap"
wlan0: interface state UNINITIALIZED->ENABLED
wlan0: AP-ENABLED
Seems odd that cat /sys/module/bcmdhd/parameters/op-mode says 0 and the
above says AP-ENABLED
Phil_in_China
Hi Dave
I used wpa-cli commands, see http://nanopi.org/NanoPi_Quick%20Start.html
for some suggestions. I did manage to get my nanopi connected to the net.
Thank you.
OK, I see there are few extra sections in that document.
wpa_cli -iwlan0 scan
OK
wpa_cli -iwlan0 scan_result
bssid              freq  signal level  flags            ssid
1c:af:05:39:1a:93  2437      -59       [WPA2-PSK-CCMP]  [ESS]AndroidAP8362
There is no /usr/sbin/wpa_action to edit.
I changed the sample wlan0 file:
auto lo
auto wlan0
iface wlan0 inet static
address 192.168.43.10
netmask 255.255.255.0
broadcast 192.168.43.255
gateway 192.168.43.1 (my WiFi Hotspot)
wpa-driver wext
wpa-ssid YourWiFiESSID
wpa-ap-scan 1
wpa-proto RSN
wpa-pairwise CCMP
wpa-group CCMP
wpa-psk YourWiFiPassword
The command route seems to indicate that the NanoPi has found the Hotspot.
And ifconfig -a shows the correct information.
I am also puzzled why lsusb shows nothing and dmesg | tail does not look
anything like the example in the guides.
Ugh.  Make sure you are using a USB data cable not a USB power only cable
Lukluk
Hi all,
Last night, I've been successfully connected to Android AP Tethering mode
by using wifi mode on NanoPI, I'm using OpenWrt Chaos Calmer 15.05 as a
root file system, and connect to AP with some wireless tools package (not
default luci wifi tools)...
But still at my thinking that it seems to be has a driver problem,
since i keep got erorr authentication while connecting to my TP-LINK AP...
I will post some connection steps and logs that probably could be solved at
this forum...
Lukluk
Here is my logs:
root@OpenWrt:~# cat /etc/wpa_supplicant.conf
ctrl_interface=/var/run/wpa_supplicant
ctrl_interface_group=0
ap_scan=1
network={
        ssid="AndroidAP"
        psk="myAPpass"
network={
  ssid="TP-LINK_7506B4"
  psk="myAPpass"
root@OpenWrt:~# iwinfo wlan0 info
wlan0     ESSID: unknown
          Access Point: 00:00:00:00:00:00
          Mode: Client  Channel: unknown (unknown)
          Tx-Power: unknown  Link Quality: unknown/70
          Signal: unknown  Noise: unknown
          Bit Rate: unknown
          Encryption: unknown
          Type: nl80211  HW Mode(s): 802.11bg
          Hardware: 02D0:A962 0000:0000 [Generic MAC80211]
          TX power offset: unknown
          Frequency offset: unknown
          Supports VAPs: no  PHY name: phy0
root@OpenWrt:~# iwinfo wlan0 scan
Cell 01 - Address: 90:F6:52:75:06:B4
          ESSID: "TP-LINK_7506B4"
          Mode: Master  Channel: 6
          Signal: -89 dBm  Quality: 21/70
          Encryption: mixed WPA/WPA2 PSK (TKIP, CCMP)
root@OpenWrt:~# ip link set wlan0 up
root@OpenWrt:~# ifconfig
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:144 errors:0 dropped:0 overruns:0 frame:0
          TX packets:144 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:9792 (9.5 KiB)  TX bytes:9792 (9.5 KiB)
usb0      Link encap:Ethernet  HWaddr E2:75:EB:29:F3:B2
          inet addr:192.168.3.1  Bcast:192.168.3.255  Mask:255.255.255.0
          inet6 addr: fe80::e075:ebff:fe29:f3b2/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:467 errors:0 dropped:0 overruns:0 frame:0
          TX packets:333 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:44767 (43.7 KiB)  TX bytes:52610 (51.3 KiB)
wlan0     Link encap:Ethernet  HWaddr 04:E6:76:6F:F6:A2
          inet6 addr: fe80::6e6:76ff:fe6f:f6a2/64 Scope:Link
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:7 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:818 (818.0 B)
root@OpenWrt:~# wpa_supplicant -i wlan0 -c /etc/wpa_supplicant.conf
Successfully initialized wpa_supplicant
wlan0: Trying to associate with 90:f6:52:75:06:b4 (SSID='TP-LINK_7506B4'
freq=2437 MHz)
wlan0: CTRL-EVENT-ASSOC-REJECT bssid=90:f6:52:75:06:b4 status_code=1
freq=2437 MHz)
freq=2437 MHz)
freq=2437 MHz)
wlan0: CTRL-EVENT-SSID-TEMP-DISABLED id=2 ssid="TP-LINK_7506B4"
auth_failures=1 duration=10 reason=CONN_FAILED
wlan0: CTRL-EVENT-SSID-REENABLED id=2 ssid="TP-LINK_7506B4"
freq=2437 MHz)
auth_failures=2 duration=23 reason=CONN_FAILED
^Cnl80211: deinit ifname=wlan0 disabled_11b_rates=0
wlan0: CTRL-EVENT-TERMINATING
          Signal: -88 dBm  Quality: 22/70
Cell 02 - Address: 9A:FA:E3:47:CB:29
          ESSID: "AndroidAP"
          Mode: Master  Channel: 1
          Signal: -87 dBm  Quality: 23/70
          Encryption: WPA2 PSK (CCMP)
wlan0: Trying to associate with 9a:fa:e3:47:cb:29 (SSID='AndroidAP'
freq=2412 MHz)
wlan0: Associated with 9a:fa:e3:47:cb:29
wlan0: WPA: Key negotiation completed with 9a:fa:e3:47:cb:29 [PTK=CCMP
GTK=CCMP]
wlan0: CTRL-EVENT-CONNECTED - Connection to 9a:fa:e3:47:cb:29 completed
[id=0 id_str=]
root@OpenWrt:~# iw wlan0 link
Connected to 9a:fa:e3:47:cb:29 (on wlan0)
  SSID: AndroidAP
  freq: 2412
  signal: -91 dBm
  tx bitrate: 52.0 MBit/s
root@OpenWrt:~# udhcpc -i wlan0 -b
udhcpc (v1.23.2) started
Sending discover...
Sending discover...
Sending select for 192.168.43.193...
Lease of 192.168.43.193 obtained, lease time 43200
udhcpc: ifconfig wlan0 192.168.43.193 netmask 255.255.255.0 broadcast
192.168.43.255
udhcpc: setting default routers: 192.168.43.1
          RX packets:384 errors:0 dropped:0 overruns:0 frame:0
          TX packets:384 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:26112 (25.5 KiB)  TX bytes:26112 (25.5 KiB)
          RX packets:775 errors:0 dropped:0 overruns:0 frame:0
          TX packets:569 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:68122 (66.5 KiB)  TX bytes:86424 (84.3 KiB)
          inet addr:192.168.43.193  Bcast:192.168.43.255
Mask:255.255.255.0
          RX packets:8 errors:0 dropped:0 overruns:0 frame:0
          TX packets:12 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:1349 (1.3 KiB)  TX bytes:2092 (2.0 KiB)
Is the signal level getting marginal?  Later on -91dBm, I am surprised that
it is still working.
Can you get closer to the TP-Link and see if your command:
works successfully?
192.168.3.1  Are you setting your own usb0 IP address, mine is
192.168.100.1
Lukluk
I'm not sure that's accurate, coz I place my devices near me (not far than
1 meter)
works successfully?
Yeah, I'm curious too, since TP-Link use mixed method:
will post another logs soon...
192.168.100.1
Yes, I configured it my self on WebLuci of OpenWrt,
seems everything configurable on Luci, except of the wifi, it's not
detected automatically by Luci, so I should manual wifi connection
instead...
Btw, I'm using rootfs taken from
openwrt-15.05-kirkwood-generic-rootfs.tar.gz, which was available here:
http://downloads.openwrt.org/chaos_calmer/15.05/kirkwood/generic/
and installed some wifi tools from its distribution packages...
Finally got the NanoPi to find my Smartphone's HotSpot, so now have access
to the internet.
And put in the suggested wlan0 file at /etc/network/interfaces.d/
When I did /etc/init.d/networking restart I looked at all the messages I
saw on the UART and at the top there was a suggestion:
   systemctl daemon-reload
So, I dropped that in on the command line and after that finished I did
another /etc/init.d/networking restart
Saw the same suggestion again, but this time when I pinged 8.8.8.8 it
worked.
Work for anyone else?
