Hi, I have mini2440 with these info: ========================================================= [root@FriendlyARM /]# uname -a Linux FriendlyARM 2.6.32.2-FriendlyARM #1 Tue Sep 21 18:09:15 HKT 2010 armv4tl unknown. ========================================================= [root@FriendlyARM bin]# printenv TSLIB_TSDEVICE=/dev/input/event0 USER=root LD_LIBRARY_PATH=/usr/local/tslib/lib TSLIB_TSEVENTTYPE=input OLDPWD=/ HOME=/ TSLIB_FBDEVICE=/dev/fb0 PS1=[\u@\h \W]\# TSLIB_PLUGINDIR=/usr/local/tslib/lib/ts TSLIB_CONSOLEDEVICE=none LOGNAME=root TERM=vt102 PATH=/sbin:/usr/sbin:/bin:/usr/bin TSLIB_CONFFILE=/usr/local/etc/ts.conf SHELL=/bin/sh PWD=/usr/local/bin QWS_MOUSE_PROTO=tslib:/dev/input/event0 TSLIB_CALIBFILE=/etc/pointercal ========================================================= -> vi /etc/profile : export TSLIB_CALIBFILE=/etc/pointercal export TSLIB_CONFFILE=/usr/local/etc/ts.conf export TSLIB_CONSOLEDEVICE=none export TSLIB_FBDEVICE=/dev/fb0 export TSLIB_PLUGINDIR=/usr/local/tslib/lib/ts export TSLIB_TSDEVICE=/dev/input/event0 export TSLIB_TSEVENTTYPE=INPUT export QWS_MOUSE_PROTO=tslib:/dev/input/event0 export LD_LIBRARY_PATH=/usr/local/tslib/lib ========================================================= the ts_calibrate worked well the demo is worked well but my app just show and the touch not worked.at first i said maybe my app has problem , so i copy the example of Qt4.6.3 (/opt/qt-everywhere-opensource-src-4.6.3/examples/widgets/calculator) on the mini2440 board. as the same as my app just show the program and the touch is disable. where is the problem. Note: I comment qtopia and i wrote cat /dev/input/event0 and my touch is worked . but when the app is open touch does not work :( WHYYYYYY o.O
the touch of my app in mini2440 not work
First go to /dev/input and type cat event0 then touch the screen. What do you see displayed on the screen? Also, tells as all the entries in /dev/input as it looks like you are not actually export(ing) the touchscreen only the mouse. Does your keyboard work?
hi and thanks for reply [root@FriendlyARM /udisk]# cd /dev/input/ [root@FriendlyARM input]# ls event0 mice =============================================== [root@FriendlyARM input]# cat event0 7�G7H�7!H7��7&am p;#65533;��7��7.� after each touch show me characters like these =============================================== i don't know how to use keyboard. if you say the keyboard on bottom of my lcd? no it does not show any keyboard to me. i change this to: export QWS_MOUSE_PROTO="tslib:/dev/input/event0 IntelliMouse:/dev/input/mice" but not worked.(but ts_calibrate worked) where is my mistake :(
Here is what I use: MINI2440_TOUCHEVENT=/dev/input/touchscreen # Qt relevant settings export QWS_MOUSE_PROTO="MouseMan:/dev/input/mice Tslib:${MINI2440_TOUCHEVENT}" expands to: export QWS_MOUSE_PROTO="MouseMan:/dev/input/mice Tslib:/dev/input/touchscreen But you haven't got /dev/input/touchscreen Do you know what type of touchscreen you have? Number on the back and whether is it 1-wire or the resistive type. If 1-wire search <1-wire touchscreen> on this site.
It has been years since I used 2.6.32.2 I recall that the touchscreen did not show up as /dev/touchscreen, but as something else. Also, there were different kernel versions depending on which touchscreen you used or has that changed?
hi i don't have any touchscreen in my dev directory [root@FriendlyARM /dev]# ls adc mixer pcmC0D0c tty15 tty32 tty5 ttySAC0 audio mtd0 pcmC0D0p tty16 tty33 tty50 ttySAC1 backlight mtd0ro ptmx tty17 tty34 tty51 ttySAC2 buttons mtd1 pts tty18 tty35 tty52 urandom camera mtd1ro pwm tty19 tty36 tty53 vcs console mtd2 random tty2 tty37 tty54 vcs1 controlC0 mtd2ro root tty20 tty38 tty55 vcs2 cpu_dma_latency mtd3 rtc tty21 tty39 tty56 vcs3 device mtd3ro rtc0 tty22 tty4 tty57 vcs4 dsp mtd4 shm tty23 tty40 tty58 vcsa fb0 mtd4ro timer tty24 tty41 tty59 vcsa1 full mtdblock0 tty tty25 tty42 tty6 vcsa2 i2c mtdblock1 tty0 tty26 tty43 tty60 vcsa3 input mtdblock2 tty1 tty27 tty44 tty61 vcsa4 kmsg mtdblock3 tty10 tty28 tty45 tty62 watchdog leds mtdblock4 tty11 tty29 tty46 tty63 zero log network_latency tty12 tty3 tty47 tty7 loop network_throughput tty13 tty30 tty48 tty8 mem null tty14 tty31 tty49 tty9 =========================================================== help me plz. what can i do now? how to enable the touch in my program? do you have an example for mini2440 with source code. maybe my Qt and compiler have mistake.
> Do you know what type of touchscreen you have? Number on the back and > whether is it 1-wire or the resistive type. I am trying to help, how about answering my question? The kernel has to know which touchscreen you are using. The 2.6.32.2 that I used years ago had different config files for the different touchscreens. OK, I had a look here: https://www.mediafire.com/folder/9cs8fenf225et//2440Board#4tssbkjb68p4m and I see lots of images for the various touchscreens. Which one are you using?
Hi and especial thanks davef for help. I have tiny 6410 too. i test all of them in 6410 and the touch is work in my application. ( the same way in mini2440) i guess maybe my Linux is not correct. maybe my base problem is my Linux on mini2440. You asked me about touchscreen. I know my touch screen is in /dev/input/event0 because when i changed it the ts_calibrate not worked. I don't have 1-wire in my device. ( I don't see anything like this)my kernel is 2.6.32 also. I guess maybe i should change the Linux and use another image.because i can run the touch in 6410 very easily. "and I see lots of images for the various touchscreens. Which one are you using?" i think i used zImage_x35. i don't know whats the different really really thanks again
You have to know which LCD you have connected to the mini2440. There are different images for different sizes and manufacturers. < Number on the back (of the LCD). You must picked zImage_35 for a good reason. Qt apps run on the mini2440, maybe not as quickly as on the mini6410, but you should be able to get them to work. I use the Qt /demo/browser app on my mini2440. There is a good site, Goggle <mini2440vietnam>
thank you devef, i have a question: what is the difference between zImage_N35 zImage_P35 zImage_T35 zImage_TD35 zImage_W35 zImage_X35 ? i know my lcd is 3.5 inch. i searched in internet and find just these : zImage_n35 - Support for NEC 3.5 "LCD in the kernel file zImage_x35 - Support for SONY 3.5 "LCD in the kernel file zImage_w35 - Support for 3.5 " landscape LCD in the kernel file zImage_T35 - Support for TPO 3.5 "LCD in the kernel file zImage_a70 - Support group Chong 7 "LCD in the kernel file zImage_L80 - Support for Sharp 8 "LCD (or compatible model) of the kernel file zImage_vga1024x768 - Support VGA expansion module (resolution of 1024x768 @ 70Hz) of the kernel file but for the other version i cant find any thing. and how do i know which LCD i have?
The difference is totally due to the touchscreen on your particular mini2440. Unfortunately my mini2440s are in another location, however ... I would use a nutdriver and carefully remove the nuts holding the LCD to the main board. I believe you then will be able to see a number on the backside. Maybe, the number is on the printed circuit board. I would have thought any documentation would tell you which one you have. > but for the other version i cant find any thing. Do you know that there is another version? I think there is a w35i (?) which is a 1-wire touchscreen. That is why I mentioned it before. I suppose another way to find out which you have is to try all the images on it, until you get one that works. Mine are n35 which was one of the earliest touchscreens that came with the mini2440. Post a picture of the backside of the LCD board.
yes, you say exactly right, when i see the back of my LCD i see this" the type of LCD is T35" . really thanks. i didn't see that. so i go to change the Linux to zImage_T35 and say the result here.
I asked you 3 days ago which touchscreen you had. You need to carefully read and understand if you are asked questions. Is this a school project, work or a hobby?
dont mock me. the Lcd is attached to board and when you say about this i dont know the type of lcd is write on the back. this device is bought in 2010 and they give it to me in this year, it is my job and i am new in embedded device. cause of this i am so confused in it. i changed the linux to zImage_T35 . but my project not worked. [root@FriendlyARM /]# printenv TSLIB_TSDEVICE=/dev/input/event0 USER=root TSLIB_TSEVENTTYPE=INPUT LD_LIBRARY_PATH=/usr/local/tslib HOME=/ QTDIR=/usr/local/Qt TSLIB_FBDEVICE=/dev/fb0 PS1=[\u@\h \W]\# TSLIB_PLUGINDIR=/usr/local/tslib/lib/ts TSLIB_CONSOLEDEVICE=none LOGNAME=root TERM=vt102 PATH=/sbin:/usr/sbin:/bin:/usr/bin TSLIB_CONFFILE=/usr/local/etc/ts.conf SHELL=/bin/sh QWS_DISPLAY=LinuxFB:mmWidth=105:mmHeight=140 PWD=/ TSLIB_CALIBFILE=/etc/pointercal QWS_MOUSE_PROTO=Tslib:/dev/input/event0 [root@FriendlyARM /]# /udisk/prj3 -qws /udisk/prj3: error while loading shared libraries: libts-1.0.so.0: cannot open shared object file: No such file or directory i used [root@FriendlyARM /]# ln -s /usr/local/Qt/lib/libts-1.0.so.0 /usr/local/lib/libts-1.0.so.0 but not worked.
edit> Do you know what type of touchscreen you have? Number on the back and whether is it 1-wire or the resistive type. yes you say it but i don't understand the meaning of back. i dont know the number wrote on the back. SORRY
it solved. but again my first problem occured. demo touch is worked. my program touch is NOT WORKED. so the linux zImage_T35 does not SOLVED MY PROBLEM and i have problem again :(
I wasn't mocking you. Just pointing out that when you don't answer questions that people put to you that the process becomes even more difficult to resolve. I never expected you to just know the number was on the back that is why I suggested you look. Now that you possibly have a working image on the board are you saying that you still don't see the directories or files that you were originally looking for? /udisk/prj3: error while loading shared libraries: libts-1.0.so.0: cannot open shared object file: No such file or directory This problem has been discussed several times over the last few months. Now is when I ask ... which tutorial are you trying to follow?
You say right and i said Really Sorry. that problem is solved. I said the first problem is occurred again. this is my tutorial :https://importgeek.wordpress.com/2012/04/09/compiling-qt-and-tslib-for-m... this is look like mini2440vietnam. at first : i install Linux on mini2440 as mentioned in mini2440vietnam then copy the tslib file to mini2440. the the base problem occured : http://www.friendlyarm.net/forum/topic/6417#30311 i guess maybe i should test the other zImage. (i installed zImage_x35 before but not worked)
suddenly happen strange ting to me, i installed Linux zImage_X35 and copy the tslib. then run my project, i run with NO touch. then i run the demo but not run and show me the error :./wigglyMain: error while loading shared libraries: libts-0.0.so.0: cannot open shared object file: No such file or directory. the strange happening is why my program run and does not show this error but the main demo show error? maybe my program does not use this library and cause of these the touch does not work? (I know how to solve the libts-0.0.so.0 problem. my main Question is why my program run without this error?)
If your touchscreen says T35 then you have to run zImage_T35. my main Question is why my program run without this error?) Programs have to be written so they are capable of "throwing error messages". Maybe "my program" is NOT written like "main demo". Could you check that you can do a ts_calibrate before you trying to run any Qt programs?
I installed zImage_T35 but my problem does not solve. you say correct. "Maybe "my program" is NOT written like "main demo"". but i set compiler in Qt like mini2440vietnam. and compile it. the ts_calibrate is run. but my application does not have touch :( again
"my program" could compile but still not "throw error messages". Is there a program called ts_test on your mini2440? I had a quick read of the tutorial you mentioned. He seems to have had many questions to answer. Getting Qt programs to run on the mini2440 is NOT an easy task. Here is a link to another forum that got lots of traffic a few years ago. http://billforums.station51.net/ I had lots of issues trying to get a Qt type web browser to work. I have been using the Pengutronix mini2440 BSP for the past 4-5 years with success, running several demo Qt programs on it. You said you are doing this for work. Do they hope to develop applications using Qt for this platform?
Sorry for everything and Thanks for help. "Is there a program called ts_test on your mini2440?" there is no file naming ts_test in mini2440. "I had a quick read of the tutorial you mentioned. He seems to have had many questions to answer." i searched in my tutorial about my problem but there were not any good answer to help me. "Getting Qt programs to run on the mini2440 is NOT an easy task." i do the same for tiny6410 and it worked. but in mini2440 not worked :( and thanks for link. i saw that and searched in that. but can not find good answer. "You said you are doing this for work. Do they hope to develop applications using Qt for this platform?" yes. cause of its cost is cheaper. it is so smaller for basic job in industrial working. --->Do you have a better suggestion? (a bout the another device like this)
Here is one problem that we had with getting Qt to work, basically it is getting the correct library path, as discussed here: http://www.friendlyarm.net/forum/topic/4853 QMAKE_LFLAGS = -Wl,-rpath-link=/home/orbit/OSELAS.BSP-Pengutronix-Mini2440-2012.12.0/platform-m ini2440/sysroot-target/usr/lib So, for you: QMAKE_LFLAGS = -Wl,-rpath-link=/path/to/your/usr/lib I am not suggesting that this is your problem.
i used it and see the post like this in another site "QMAKE_LFLAGS = -Wl,-rpath-link=/path/to/your/usr/lib"
The mini2440 hardware design and build quality are quite good. I have only had the power jack and SD card holder fail on me. The mini2440 uses a processor that is now obsolete. The mini2541 has a more current processor but I don't much on-line support for it. The mini2440 was popular 3-5 years ago and still seems to be used in educational environments. I won't make any suggestions here but if you want to discuss further I would give you my email address.
Hi again. sorry i cant find that site explain a bout :"QMAKE_LFLAGS = -Wl,-rpath-link=/path/to/your/usr/lib" . just i remember that site about hacking to install tslib and Qt 4.6.3 on Ubuntu.and a bout mini2451. thanks for suggestion. (If i find the answer, i put it here and thanks for your support)
Don't worry about it. Interesting that you mention the mini2451. If there is a site giving some support for the mini2451 that would be interesting. Email: dave_festing at hotmail dot com Tell me what you hope to design and what resources you have, that might help me make better suggestions.
Hi Hani, I am facing EXACTLY the same "touchscreen not working issue" like you. And, like you, i also have referred to the same link (https://importgeek.wordpress.com/2012/04/09/compiling-qt-and-tslib-for-m...). Did you get your touchscreen to work ?? If yes, please tell me how you got the touchscreen to work. Thank you in advance.
