Hello, I was been away for 2 years from development Qt applications for the Mini6410. Is it possible to update or new install Qt 5.5? Is there a tutorial to cross-compile Qt 5.5 for the Mini (on a 64 bit (amd64) maschine I prefered)? The toolschain from FriendlyARM is 32bit. I read there is no qws in that Qt? I feel I begin from 0... Need I update the OS on the Mini? Many questions ;-) This: http://www.friendlyarm.net/forum/topic/4260#20044 was from me. But I can't reproduce it anymore on my actual pc. cheers Holger
QT 5.5 with Mini6410
Hi. More than 1 year ago I used QT 5.2.X. Normally you will find about compiling QT 4.x but for me didn't work it because some things changed from QT4 to QT5. After trying some things I was able to compile it. These are the commands that I used(I saved in a file for later) 1. Configure ./configure -v -opensource -confirm-license -xplatform linux-arm-gnueabi-g++ -prefix /usr/local/QT/ -no-xcb -no-cups -no-dbus -no-glib -no-pch -no-nis -no-accessibility -no-gtkstyle -nomake examples -nomake tests -nomake webkit -nomake wayland -nomake qtmultimedia make -j 4 2. Compile make make install Check the first command because probably you need to change some parameters. Normally you can use the same system and just change the path to the new QT libraries. I used my own Debian version with the compiled libraries and this week I am trying to start again all the work(Boot from SD, compile new Kernel version, create my Debian version, load the Debian from the SD, compile QT 5.5.1 and test one app) yesterday I downloaded the toolschain, kernel source and today the QT source. I used my board just for testing and all was for learning it was my first steps with a board. 1 year ago I recreate all to enter a contest and I used QT 5 to develop and app with GUI, REST(communicate with a webservice) and to use NFC, all worked with the configuration that I used to compile QT I don't know for you. I used 5.2.x and now I will try with 5.5.1
