Hello everyone ! I have friendlyarm Mini 2440 board and I installed Linux without any problems. I am interested if there is a way to connect the board with my computer , so I can see the GUI on it ? ( Like raspberry pi and Remote Desktop Connection ) Best Regards
Connecting mini 2440 with pc
<vnc linux arm> into Google? Specifically, <vnc linux arm9 friendlyarm> http://www.friendlyarm.net/forum/topic/5029
I am trying to connect mini2440 (in NOR mode) to my laptop (UBUNTU 14.04 LTS, 64 bit) using USB cable to transfer files. i am not able to transfer files using 's3c2410_boot_usb'. i am getting error 'Cannot find QT2410 device in bootloader mode'. the information output of 'lsusb -v' command is as shown below. mini2440 board is showing as 'Owon PDS6062T Oscilloscope' 'Bus 002 Device 031: ID 5345:1234 Owon PDS6062T Oscilloscope Couldn't open device, some information will be missing' =========================================================================== Bus 002 Device 031: ID 5345:1234 Owon PDS6062T Oscilloscope Couldn't open device, some information will be missing Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 1.10 bDeviceClass 255 Vendor Specific Class bDeviceSubClass 0 bDeviceProtocol 0 bMaxPacketSize0 8 idVendor 0x5345 Owon idProduct 0x1234 PDS6062T Oscilloscope bcdDevice 1.00 iManufacturer 1 iProduct 2 iSerial 0 bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 32 bNumInterfaces 1 bConfigurationValue 1 iConfiguration 0 bmAttributes 0xc0 Self Powered MaxPower 50mA Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 2 bInterfaceClass 255 Vendor Specific Class bInterfaceSubClass 0 bInterfaceProtocol 0 iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0020 1x 32 bytes bInterval 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x03 EP 3 OUT bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0020 1x 32 bytes bInterval 0 ======================================================================= Can any one help me on how to solve this problem? Is there any driver instalation process in ubuntu 64 bit os?
