Hello, i am trying to install boot loader on mini2440 board with following images through serial and data cable. 1] superboot2440.bin 2] zImage_T35 3] rootfs_qtopia_qt4.img and after switching to NAND mode, there is only white display. No booting of OS ? Can you tell me, where's the problem?
min2440 bootloader installing problem
never try the superviva but superboot seems obviously detail in their manual to install OS. i tried install linux two weeks ago and did it. why dont u use superboot?
Hello Nik Are you using DNW tool for installing linux? if is that so you should use supervivi-128M. It will be helpfull if you use latest images present in DVD, which came with board.
