Hello all! I am newbie here, i got my tiny4412 last week and have installed linux in it. I'm making some project ADC with the i2c protocol which will gather the data and show it. I wonder if the data can be showed in some apps in my qtopia, i have read a little about qt, but still i am confusing. Do you have any idea or good reading for my little steps to build the project? thank you.
[ask]i2c + Qt
Have a look through these sites: http://paolosereno.info/ He had more info on an older site. Also, search <domdom> on this site, which hopefully will take you to collection of his tutorials. Then read through this stuff: http://mini2440vietnam.blogspot.co.nz/
Hi all, thanks Dave to redirect to my new blog. I'm changing the web provider and I had some trouble to move the domain, so I decided to redirect all the requests to the address you wrote in your post. At the moment I put online the most requested tutorials, but there is much more material I have to move to the new site. Please stay tuned. Regards, Paolo
hi paolo soreno Thank you, i am waiting for your new site. but i have tried some of the qt stuff in your site really helpful. regards azihsan
@azihsan Thanks for your feedback. It's important for me to know that the Qt stuff in my site is helpful to someone. Regards Paolo
Hey all i have finished to build a cross compiled program for i2c, but when i am tryin to run in my tiny4412 it came PERMISSION DENIED, so what shuold i do?
Hey I just solved the problem with chmod +x myExeName but i got a problem again with my i2c bus channel, when i tried i2c-0 and i2c-1, the result came up with -1 what should i do?
On your host computer command line type: readelf -a <your_cross_compiled_program> and copy the last 10 lines or so from the output
is it like this davef? File Attributes Tag_CPU_name: "ARM1176JZF-S" Tag_CPU_arch: v6K Tag_ARM_ISA_use: Yes Tag_THUMB_ISA_use: Thumb-1 Tag_FP_arch: VFPv2 Tag_ABI_PCS_wchar_t: 4 Tag_ABI_FP_denormal: Needed Tag_ABI_FP_exceptions: Needed Tag_ABI_FP_number_model: IEEE 754 Tag_ABI_align_needed: 8-byte Tag_ABI_align_preserved: 8-byte, except leaf SP Tag_ABI_enum_size: int Tag_ABI_HardFP_use: SP and DP
hey davef it seems i succeed to open the i2c file. but i cant read my ADC ic, i use this code, is there something wrong? because i completely succeed to run the program in my Pi. int numberBytes = ADS1110_Buffer; int bytesRead = read(file, this->dataBuffer, numberBytes); if (bytesRead == -1){ cout << "Failure to read Byte Stream in readFull()" << endl; }
Tag_CPU_name: "ARM1176JZF-S" Tag_CPU_arch: v6K These indicate that at least your have cross-compiled it for ARM. I am not familiar with the exact name and arch, so you have to look those up.
Sorry, unless I actually tried it myself I can not be of anymore help. I think for anyone to help they would need to see the whole program.
