Kernel 3.2 compilation for mini2440 the error comes in the file linux-3.2/drivers/video/backlight/pwm_bl.c in function pwm_backlight_suspend undefined reference to pwm_set_duty_ns, pwm_stop in function pwm_backlight_remove undefined reference to pwm_set_duty_ns,pwm_stop,pwm_release in function pwm_backlight_update_status undefined reference to pwm_set_duty_ns,pwm_stop,pwm_start . . . Pls help some one how to overcome Tarn
kernel compilation error
Common problem is that the compiler can't find those functions. There should be a file called pwm_blc.h which defines those functions. Can you find that file in the same directory as pwm_blc.c
