Facing issue in cross compiling Qt
Abhi11
Hi Guys,
I am using mini2440 board and linux as my working platform.
I have some issue in running cross compiling the QT_4.8.5.I am using this
command to cross-compile as mentioned in this tutorial
(https://www.youtube.com/watch?v=-_YzWgGJgKU).
./configure -prefix /qtebuild/ -release -shared -fast -pch -no-qt3support
-qt-sql-sqlite -no-libtiff -no-libmng -qt-libjpeg -qt-zlib -qt-libpng
-qt-freetype -no-openssl -nomake examples -nomake tools -nomake demos
-optimized-qmake -no-phonon -no-opengl -no-nis -no-cups -no-xcursor
-no-xrandr -no-xfixes -no-xrender -no-xkb -no-sm -no-xinerama -no-xshape
-no-separate-debug-info -xplatform qws/linux-arm-g++ -embedded arm -depths
16 -no-qvfb -qt-gfx-linuxfb -qt-gfx-qvfb -no-kbd-qvfb -no-mouse-qvbf
-qt-kbd-usb -confirm-license -qt-mouse-tslib
I am having some issue in this command.It is throwing error.
-no-mouse-qvbf: unknown argument
-qt-mouse-tslib: unknown argument
If I am removing these arguments then it is working but without this
"qt-mouse-tslib" argrument does my touch works ?
Please share your views
Regards
Abhinav
Maybe check out this tutorial to see there are any clues:
http://mini2440vietnam.blogspot.co.nz/2011/04/upgrade-qt462-in-mini2440....
I see he doesn't have the -no-mouse-qvbf, but does have -qt-mouse-tslib.
Ah, have you compiled tslib fist?
Abhi11
Noops.I haven't cross compiled tslib
Is tslib source code is available in DVD that comes with board.
After cross compiling tslib should I have to give some path or what should
I have to do ?
Suspect it is not on the  DVD as the tutorial suggests getting it from
github.
It has been about 2 years since I tried this tutorial, but suspect that
path details are sorted out for you.
Did the video not tell you to cross-compile tslib first?
Abhi11
Hi davef
No in video I didn't find any thing like tslib
I have taken the source code of tslib from github.I have also downloaded
the pre-compiled tslib from the vietnam blog.
Now can guide what steps I have to follow to get it work.
Regards,
Abhi
Is this a question?
Or, do you mean,
"Now I understand what steps I have to follow to get it to work."
Abhi11
Sorry for your confusion..
But I am asking question..Does Qt cross-compilation has some dependecies on
tslib ?
Yes.
Qt has to be able to find tslib if you use -qt-mouse-tslib
If you follow that tutorial you should see that tslib is put into a
directory that should be found when you cross-compile Qt.
From the tutorial:
#after succesful tslib compilation, you will see tsblib in /home/tslib
root@phuc-laptop:/usr/local/tslib# cd /home/tslib/
root@phuc-laptop:/home/tslib# ls
bin  etc  include  lib
Abhi11
So you want to say that my cross compiled tslib shud be at this location
/home/user_name/tslib
Then my QT cross compilation takes this path for tslib.Do you want to say
this.
Well, that is what I read in the tutorial.  When I did this I didn't have
any tslib related problems.
I am sure it must be in the translation, but it sounds like you are going
to take me to court if this doesn't work for you :)
When you cross-compiled tslib following the instructions in the tutorial
did you find some files in /home/tslib?  If so, that seems a positive step.
Then when you cross-compile Qt did you get the error that started this
thread?
Abhi11
Ok I will try that ..
I more thing act I want to run my own GUI on mini2440 and that why I am
doing all this stuff.
One more doubt that I have is for cross compiling Qt we are making
modification in qmake.conf file inside dir linux-arm-g++.We are giving path
of our toolchain.Why we are not using qmake.conf inside dir
linux-gnueabi-arm-g++ as our toolchain is arm-none-linux-gnueabi ?
From the tutorial:
$cd
/usr/local/qt-everywhere-opensource-src-4.6.2/mkspecs/qws/linux-arm-g++/
$gedit qmake.conf
linux-arm-g++ is the name of the directory and has nothing to do with the
toolchain.  As far as I understand.
I think it would be best if you work through each step in the tutorial and
post your error messages BEFORE trying to proceed to the step.
If you use the tutorial I linked to you stand a much better chance of
getting help from me and others.
