HI! On a mini2440, I need to restrict access for a certain user to a given directory, which is located on an SD card. This SD card is currently formatted as FAT, but it may be formatted with a Linux FS if required. Any hint? Thank you!
restrict user access / ACL
Is not sudo and placing the appropriate permissions on a file what you need? I believe the standard mini2440 comes without sudo, maybe you have to build a custom version of Busybox. Or, is getting sudo to work on an external SD card the problem? Google sudo sd card external Good luck
Thanks for your answer. I need that the a given user cannot cd out of its home dir, nor affect anything outside its home dir. I will follow your hint on the net. Regards
