Hi Everybody, I am developing application using stamp module compatible to EM2440 board. I have to run our application to this board which we have developed in FriendlyARM development board. We have used our development platform using "qt-everywhere-opensource-src-4.7.3" and cross compilation tools arm-none-linux-gnueabi version 4.4.3. But the shared library generating after cross compilation is not compatible to your kernel version "GLIBC_2.9" missing. Now we have overcome that problem using crosscompiler provided by brodcon (version 4.3.3) and "qt-everywhere-opensource-src-4.6.3" and using the latest "tslib" : git clone http://github.com/kergoth/tslib.git Now our custom GUI is loading. But now the problem is touch panel is not working. I have followed the tutorial below:- https://importgeek.wordpress.com/tag/qtopia/ My configuration --------------------------------------------------------------------------- /etc/profile --------------------------------------------------------------------------- # Ash profile # vim: syntax=sh # No core files by default #ulimit -S -c 0 > /dev/null 2>&1 USER="`id -un`" LOGNAME=$USER PS1='[\u@\h \W]# ' PATH=$PATH HOSTNAME=`/bin/hostname` export USER LOGNAME PS1 PATH export LD_LIBRARY_PATH=/usr/local/tslib/lib export QTDIR=/usr/local/Qt #export QWS_MOUSE_PROTO=tslib:/dev/input/event0 #export QWS_MOUSE_PROTO=tslib:/dev/event0 export QWS_MOUSE_PROTO=/dev/event0 #export QWS_MOUSE_PROTO="Auto" export TSLIB_CALIBFILE=/etc/pointercal #export TSLIB_CONFFILE=/usr/local/etc/ts.conf export TSLIB_CONFFILE=/etc/ts.conf export TSLIB_CONSOLEDEVICE=none export TSLIB_FBDEVICE=/dev/fb0 export TSLIB_PLUGINDIR=/usr/local/tslib/lib/ts export TSLIB_TSDEVICE=/usr/local/tslib/lib/ts export TSLIB_TSEVENTTYPE=INPUT export QWS_DISPLAY=LinuxFB:mmWidth=105:mmHeight=140 Please, help me to resolve this problem.I am Cluless.Pleaease,please help me!!!!!!!!!!!
EM2440-Touch panel is not working,please help!.
I was surprised to read that a cross-compiler built for the Broadcom (?) chip would work on the mini2440 armv4t architecture. Is that correct? Next, there are many different types of touchscreens, so there are many threads around about the struggles various people have had. What is the display that you are using? Was your cross compilation tools "arm-none-linux-gnueabi version 4.4.3" supplied by the distributor for this board? I assume you tried to fix the "GLIBC_2.9" missing problem before you changed tools.
Hi davef, Thanks for your reply.Yes you are wright.I mentioned wrongly "Broadcon board". Actually it is "Samsung S3C2440A ARM920T". I brought from the following site. http://www.armdesigner.com/EM2440-III.html I am sorry but, there is no part no or anything os touch screen. It comes along with "W35" LCD model. 1.I have tried so many different tslib version. All version behave in same manner. I think I am missing something in compilation process of tslib or environment setting. 2.Please, tell me how to test the tslibrary? I got some executable form "/home/tslib/bin" eg.a)ts_calibrate,b)ts_print,c)ts_test,...... I put the the same to "/usr/local/tslib/bin" folder in "EM2440" board. When I run the follwing command. 1.[root@Boardcon bin]#.ts_calibrate Couldnt open tslib config file: No such file or directory ts_config: Illegal seek 3.In my board there is no input folder in /dev file so, I put "export TSLIB_TSDEVICE=/dev/event0" a)/usr/loacal/Qt--- is my shared library for QT. b)/usr/local/tslib/lib --- is my tslib after cross compilation. c)/etc/profile export LD_LIBRARY_PATH=/usr/local/tslib/lib export QTDIR=/usr/local/Qt export QWS_MOUSE_PROTO=/dev/event0 export TSLIB_CALIBFILE=/etc/pointercal export TSLIB_CONFFILE=/usr/local/etc/ts.conf export TSLIB_CONSOLEDEVICE=none export TSLIB_FBDEVICE=/dev/fb0 export TSLIB_PLUGINDIR=/usr/local/tslib/lib/ts export TSLIB_TSDEVICE=/dev/event0 export TSLIB_TSEVENTTYPE=INPUT export QWS_DISPLAY=LinuxFB:mmWidth=105:mmHeight=140 Please reply.
I am sorry but, there is no part no or anything os touch screen. It comes along with "W35" LCD model. Appears you are using a W35 touchscreen. Putting W35 into search provides some reading material. Also, you need to know if your screen is a 1wire touchscreen. There are many pages of hits on the forum. You need to find out why ts_config is not in /etc I would suggest you follow this tutorial: http://mini2440vietnam.blogspot.co.nz/2011/04/upgrade-qt462-in-mini2440....
Hi davef, I have already tried the following site: http://mini2440vietnam.blogspot.co.nz/2011/04/upgrade-qt462-in-mini2440.... https://importgeek.wordpress.com/2012/04/09/compiling-qt-and-tslib-for-m... http://qtinstall.blogspot.in/ Nothings works for me. Is there any other step to test whether my tslib works or not? Is there any forum of this site http://www.armdesigner.com/EM2440-III.html. How people develop? Even they do not give any technical support. I have already send five mail. No reply!!!!
Thanks all.Problem has solved.Library and all file/folder structure are different in my board. If any one need help, Mail me :"rofique007@gmail.com" I will definitely help you. Rofique Anowar
Hi Rofique Anowar, I using Mini2440 and facing the same issue that touchscreen not working. I have referred the same tutorials as you:- https://importgeek.wordpress.com/tag/qtopia/ https://importgeek.wordpress.com/2012/04/09/compiling-qt-and-tslib-for-m... My tft display works fine, but my touchscreen does not work. Please tell me how you solved this problem. Thank you in advance.
