Urgent_Problem_SDL_X11!!!
Hot_Snow
I posted my problem three days ago but I didn't get a good solution.
I am working with smart210, I use the qtopia rootfs. I cross compiled a
GUI QT application named "vidgui" (an embedded video application) this
application depends on many libraries and packages such us ffmpeg, SDL,
X11...I cross compiled all the needed libraries for ARM.
When I load this application into smart210, it works proprly but when I
want to display the video (normaly the application will use the SDL and X11
libraries), the window will never be displayed and when I take a look to
the trace file: It's written that window opened and directly it's written
video closed.
Well, I make the same test with ubuntu(ARM) for smart210 and I have the
window of video was displayed correctly!!
Really, I haven't any idea what I should make, I think that I should add
the X11 plateform to the qtopia rootfs, but I haven't the source of
FriendlyARM. Also, I can't use ubuntu because my video application works
with the cmos camera of friendlyARM and also the touch screen LCD of
friendlyARM...I am blocked...anyone could help me? It's very urgent!!!!
Hot_Snow
Sorry,another information: when I execute my gui application in qtopia
rootfs, this message is written "vidgui: cannot connect to X server"
mali
Well I don't know the answer but "cannot connect to X server" message
usually happens when you try to run a GUI application in an environment
that doesn't have a display output (LCD or connected HDMI or VGA or ...)
but a terminal only.
Hot_Snow
Thank you, Mali, for your answer.well, I'm working with the smart210 and
I'm using both resistive and capacitive LCD. So, I don't think that the
problem is from the display outpout. May be the qtopia rootfs of
friendlyarm was not compiled with the X platform is the real problem.
Really,I haven't much experience to know the exact problem, but I'm nearly
sure that the problem is from the qtopia rootfs system, but I don't know
how I can slove it.
