First, I want to tell you that I use Linux OS, not Android OS I use linux kernel from the CD but it has a problem with LCD touchscreen(S702). When I port it to my tiny4412, the LCD touchscreen work but it doesn't display full and clearly,it also lags, I can't calibrate or work with it. I also try to cross-compile linux source to make new zImage but when I port it to tiny4412, LCD touchscreen don't work, it doesn't display anything. Could you give me an idea to solve this problem or upload a zImage that touchscreen work perfectly for me?
Tiny4412 and touchscreen problem
Hello , Maybe you should modify your friendlyarm.ini , such as : LowFormat = Yes Or you should use the newest superboot.bin .
Thanks jiameijiang, I have replaced arm-linux-gcc-4.3.2 with arm-linux-gcc-4.5.1 and I have recompiled linux source with it and the LCD touchscreen works perfectly.
