Stopping at bootloader
Abhi11
Hi Guys,
I am using mini2440 and I am new to this platform.Whenever I am booting
from Nand the logs I got are like this
Superboot-2440 V1.3a(20131213) by FriendlyARM
Booting from NAND
Load Kernel...
Uncompressing
Linux version 2.6.32.2-FriendlyARM (russell@russell-pc) (gcc version 4.4.3
(ctng-1.6.1) ) #8 Fri Jan 3 19:49:00 CST 4
Initially it shows some logs for superboot and then kernel starts.I want to
stop booting at bootloader.So how I can do that.
Should I have put u-boot images in nand ?Plz provide some solution
Regards,
Abhi
jiameijiang
      The superboot of friendlyarm does not suppot to stop booting at
bootloader . If you have to do this , you should use uboot .
Abhi11
Thanks jiameijiang.
Can you tell me if I have to use uboot how should I make the SD card.Means
what all images I should put in SD card ?
