3g mf210 in smart210
gabrielbonato
Dear friends,
I am a problem with zte 3g mf210 (minipcie) , I cannot to connect it with
3g network, it shows this errors below.
output in logcat
D/fanetworkservice( 1534): USB: 1d6b:0002 (bus 1, device 1)
D/fanetworkservice( 1534): USB: 1d6b:0001 (bus 2, device 1)
D/fanetworkservice( 1534): USB: 0424:2514 (bus 1, device 2)
D/fanetworkservice( 1534): USB: 19d2:0117 (bus 1, device 14)
D/fanetworkservice( 1534): USB: 3G USB Modem detected! device name: ZTE
MF210 (m
iniPCIe), device index: 108
D/fanetworkservice( 1534): >>>>11> "RESPONSE USBSTATUS DEVS 4 3G 108
D/fanetworkservice( 1534): " [END]
I/ActivityManager( 1733): Displayed
com.friendlyarm.net3gdialup/.ActivityMain: +
586ms
D/fanetworkservice( 1534): before readConfig,
g_config_isAutoConnect=0,g_config_
atCmdDeviceIndex=0,g_config_modemIndex=1,g_config_networkType="wcdma"
D/fanetworkservice( 1534): after readConfig,
g_config_isAutoConnect=0,g_config_m
odemIndex=0,g_config_atCmdDeviceIndex=1,g_config_networkType="wcdma"
/opt/FriendlyARM/android-fa-apps/fa-network-service/f
anetwork_config.c 189
D/fanetworkservice( 1534): >>>>11> "RESPONSE 3GAUTOCONNECT 0 DISABLE 0
wcdma
D/dalvikvm( 3413): GC_FOR_ALLOC freed 147K, 10% free 5799K/6407K, paused
27ms
I/dalvikvm-heap( 3413): Grow heap (frag case) to 6.465MB for 408424-byte
allocat
ion
W/InputManagerService( 1733): Starting input on non-focused client
com.android.i
nternal.view.IInputMethodClient$Stub$Proxy@4137ac10 (uid=10041 pid=1910)
D/OpenGLRenderer( 1910): Flushing caches (mode 0)
D/dalvikvm( 3413): GC_FOR_ALLOC freed 0K, 10% free 6197K/6855K, paused 21ms
D/fanetworkservice( 1534): >>>>11> "RESPONSE NETSTATUS DOWN -1 unknow
I/ActivityManager( 1733): START
{cmp=com.friendlyarm.net3gdialup/.DialupView (ha
s extras)} from pid 3413
D/fanetworkservice( 1534): ############  A client 12 connected, say
welcome!
D/fanetworkservice( 1534): ############  A client 13 connected, say
welcome!
D/dalvikvm( 3413): GC_CONCURRENT freed 569K, 15% free 6154K/7175K, paused
2ms+2m
s
D/fanetworkservice( 1534): >>>>13> "RESPONSE 3GAUTOCONNECT 0 DISABLE 0
wcdma
D/fanetworkservice( 1534): >>>>12> "RESPONSE NETSTATUS DOWN -1 unknow
com.friendlyarm.net3gdialup/.DialupView: +26
1ms
D/OpenGLRenderer( 3413): Flushing caches (mode 0)
D/fanetworkservice( 1534): #### modemIndex = 108
D/fanetworkservice( 1534): #### getModemMaxIndex() = 120
D/fanetworkservice( 1534): #### pArg = "108"
D/fanetworkservice( 1534): #### connectArgs[0] = "108"
D/fanetworkservice( 1534): #### connectArgs[1] = "wcdma-usb2"
D/fanetworkservice( 1534): #### networkType    = "wcdma-usb2"
MF210 (m
D/fanetworkservice( 1534): open /var/run/ppp0.pid error, error: No such
file or
directory
D/fanetworkservice( 1534): #### open /dev/ttyUSB1 OK!
D/fanetworkservice( 1534): #### read string from: AT
D/fanetworkservice( 1534): OK
D/fanetworkservice( 1534): #### test AT OK!
D/fanetworkservice( 1534): {{ begin call: call-ppp wcdma-usb2
D/fanetworkservice( 1534): }} end
D/fanetworkservice( 1534): fread /var/run/ppp0.pid error: No such file or
direct
ory
D/fanetworkservice( 1534): PPPD is running
D/AudioHardware( 1539): AudioHardware pcm playback is going to standby.
D/AudioHardware( 1539): closePcmOut_l() mPcmOpenCnt: 1
W/Netd    ( 1531): No subsystem found in netlink event
D/NetlinkEvent( 1531): Unexpected netlink message. type=0x11
file or
directory
file or
directory
file or
directory
file or
directory
file or
directory
file or
directory
file or
directory
file or
directory
file or
directory
file or
directory
file or
directory
file or
directory
file or
directory
file or
directory
file or
directory
file or
directory
file or
directory
file or
directory
file or
directory
file or
directory
file or
directory
file or
directory
file or
directory
file or
directory
file or
directory
file or
directory
file or
directory
D/fanetworkservice( 1534): >>>>12> "RESPONSE 3GCONNECT ERROR
V/AccountUtils( 2061): 0 accounts found with uca feature
W/GmsApplication( 2061): Using Auth Proxy for data requests.
Att,
Gabriel Bonato
