hi I have the same problem when the factory installed android is loading. I see android logo in initializing process but in most case after that the LCD goes black. it's interesting that I could drive a LED TV by connecting the HDMI cable.
LCD Loading failure
Hi I watched your video. I need more details before I can give you some ideas: 1. Was this a capacitive LCD or resistive one? 2. Was this a 210 board or a 4412 board? 3. Did you install this Android or this was the Android that came with the board? Usually when you install Android and start it for the first time it takes relatively longer before you can enter its main GUI.
My board is Tiny4412 sdk s700 whit capacitive LCD and the android is the ones that came with the board. for example if i reset the board five times, in four of that the LCD goes black(in the way that I mentioned) and once load correct and it goes to desktop screen. thank you for your attention
