Hello, I Have already mini2440 Board With A70 touch screen. and linux 2.6.32 kernel. Now After Buy Another board With above same configuration in that my touchscreen is not work .
touchscreen issue mini2440
Both have the same display variant, the same flash size and the flash chips are the same? There was a change in flash parts recently. http://comments.gmane.org/gmane.comp.embedded.ptxdist.oselas.community/2012
Thanks For link. I found new driver implement for mini2440 "/dev/touchscreen-1wire" so this 1 wire driver new implemented on kernel source. So now i calibrate successfully but not Tocheffect from my qt application. So What changed i need to do?
You have to make changes in ts.conf for that change first line of ts.conf from 'module_raw input' to "module _raw_one_wire_ts_input"
Hi Dipen, Where did you find the 1-wire touchscreen driver ? Can you share the link please ? Thank you in advance.
