update ubuntu kernel
rezanajaf
Hi
I download linux-3.8.13-nanopc-t1-140523.tar.gz and compile kernel
successfuly on my tiny4412 ubuntu
but i don't know how to update my kernel
the zimage and modules built successfuly.
copy nanopc_t1_ubuntu_defconfig to arch\arm\configs
make nanopc_t1_ubuntu_defconfig
make -j5
make mosules_install
make
can anyone help?
rezanajaf
The end line is make install
What is the first error message you get?
Maybe, try running the first make instruction and see if it is successful
then run the next one, etc.
rezanajaf
I didn't show any error but when the system is rebooted I use "uname -a"
command in terminal the kernel version was not changed
my first kernel version is 3.5 and compiled kernel version is 3.8
rezanajaf
I used used odroidx2 module before tiny4412
in odroidx2 ubuntu i copy the zImage to BOOT Partition after compile kernel
but i didn't find this partition in friendlyarm ubuntu
can you help me how i can unhide this partition in friendlyarm ubuntu?
Seems you are aware of the Odroid forum.  From my reading there getting
things setup partition-wise and SD versus eMMC seems a major hurdle.
One that I know nothing about.
Perhaps "unhide" is not the right word, do you mean create it?
Would not this process be exactly the same for the Nano, or is the Prime
variant in the X2 slightly different?
rezanajaf
Are you compile kernel for tiny4412 and update kernel?
If ok or if you know how to do this please help
No.
Gonyappa kurubar
Dear all
         please help me to rectify this error
     madhu@madhu-desktop:~/mini2440/linux-2.6.32.2$ sudo make zimage
[sudo] password for madhu:
make: arm-linux-gcc: Command not found
make: *** No rule to make target `zimage'.  Stop.
thanks in advance
  Gonyappa
Sunny Leone
Dear Gonyappa,
Use "make zImage" instead of "sudo make zImage".
Make sure you copied your configuration to ".config" file or run "make
menuconfig"
Best of Luck,
Sunny Leone.
