Hi all, PLease help me with the below error encounter while enabling xorg component. checking whether the compiler supports -Wall... yes checking whether the compiler supports -fno-strict-aliasing... yes checking for perl... /usr/bin/perl checking for arm-v4t-linux-gnueabi-gcc option to support OpenMP... -fopenmp checking whether the compiler supports -fvisibility=hidden... yes checking whether the compiler supports -xldscope=hidden... no checking whether to use MMX intrinsics... configure: error: MMX intrinsics not detected no make: *** [/home/dhruv/OSELAS.BSP-Pengutronix-Mini2440-2012.02.0/platform/state/pixman.pre pare] Error 1 Thanks, Dhruv Chawda
OSELAS.BSP-Pengutronix: pixman.prepare on enable xorg
It would be better to post mini2440 OSELAS questions to: http://blog.gmane.org/gmane.comp.embedded.ptxdist.oselas.community and to search that site and: http://blog.gmane.org/gmane.comp.embedded.ptxdist.devel
please help me to rectify this error madhu@madhu-desktop:~/ptx/ptxdist-2015.01.0$ ptxdist platformconfigerror: 'selected_ptxconfig' file is missing try 'ptxdist select <ptxconfig>' or 'ptxdist clone <project>' to clone an existing project error: The ptxconfig file version and ptxdist version do not match: configfile version: ptxdist version: 2015.01.0 You can either migrate from an older ptxdist release with: 'ptxdist migrate' or, to ignore this error, add '--force' to ptxdist's parameters, e.g.: 'ptxdist --force --auto-version platformconfig' please help me anybody Than ks in advance
First, you really should start a new thread. Looks like you are trying to use the latest mini2440 BSP. Page 10 in the QuickStart guide tells which versions of PTXdist, mini2440 BSP and toolchain you should be using. Unless you need to keep any older versions I find the easy thing to do is delete any old PTXdist versions or read how to do it properly on page 57 and 58
Dear all help me to rectify this error madhu@madhu-desktop:/home/OSELAS.Toolchain-2014.12.0/OSELAS.BSP-Pengutronix-Mini 2440$ ptxdist platform configs/platform-friendlyarm-mini2440/platformconfig-NAND-128M ptxdist: error: ptxdist-2013.09.0 not found! first time am doing , now am using 2014 tool chain thanks
Building the toolchain (compiler/linker/libs) with PTXdist has its own dependency to the PTXdist version. All PTXdist versions can co-exist.
