Trying to use default images provided with [FriendlyARM mini210s](http://www.friendlyarm.net/products/mini210s) SBC. Got the images from the DVDs that you can download on ftp.friendlyarm.net [credentials at the bottom of this page](http://www.friendlyarm.net/downloads) under the `mini210` folder. - Prepare microSD using `SD-Flashed.exe` on Windows XP machine - Copied images folder onto the microSD ## My FriendARM.ini #This line cannot be removed. by FriendlyARM(www.arm9.net) CheckOneButton=No Action = Install OS = Linux LowFormat = Yes VerifyNandWrite = No LCD-Mode = No LCD-Type = A70 CheckCRC32=No StatusType = Beeper | LED ################### Linux #################### Linux-BootLoader = Superboot210.bin Linux-Kernel = Linux/zImage Linux-CommandLine = root=/dev/mtdblock4 rootfstype=yaffs2 console=ttySAC0,115200 init=/linuxrc Linux-RootFs-InstallImage = Linux/rootfs_qtopia_qt4-mlc2.img ################### Android 4.0.3 #################### Android-BootLoader = Superboot210.bin Android-Kernel = Android/zImage Android-CommandLine = root=/dev/mtdblock4 rootfstype=yaffs2 console=ttySAC0,115200 init=/linuxrc androidboot.console=ttySAC0 gs=0 Android-RootFs-InstallImage = Android/rootfs_android-mlc2.img When trying to install Linux, I am getting this: NAND Low-level formating... NAND Low-level formatted... Superboot-210 Ver: 1.2(20120202) CPU: S5PV210 1GHz RAM: 512MB NAND: 1GB(SLC) ID:ECD35195 Touch Device: no 1-wire LCD Type: A70(Manu) Installing OS 'LINUX' Installing bootloader... file: /images/Superboot210.bin: 528 KB(540672 Byte) Installing bootloader succeed Installing kernel... file: /images/Linux/zImage: 4 MB(4810580 Byte) Installing kernel succeed Installing yaffs2-image... Installing yaffs2-image failed When trying the Android image: NAND Low-level formating... NAND Low-level formatted... Superboot-210 Ver: 1.2(20120202) CPU: S5PV210 1GHz RAM: 512MB NAND: 1GB(SLC) ID:ECD35195 Touch Device: no 1-wire LCD Type: A70(Manu) Installing OS 'ANDROID' Installing bootloader... file: /images/Superboot210.bin: 528 KB(540672 Byte) Installing bootloader succeed Installing kernel... file: /images/Android/zImage: 4 MB(4590948 Byte) Installing kernel succeed Installing yaffs2-image... Installing yaffs2-image failed [This FRIENDLYARM FORUM post](http://www.friendlyarm.net/forum/topic/5161) suggests that the image is a MLC2 NAND image whereas the NAND is SLC. I have tried rebuilding the image using the `rootfs` TAR but I am getting the same issue. Any pointers are most welcome.
Mini210s images => Installing yaffs2-image failed
- Get `rootfs_qtopia_qt4-20121108.tar.gz` from the friendlyARM DVD - Compiled [yaffs2utils](https://code.google.com/p/yaffs2utils/) on my dev environment. ### Rebuilt the image sudo tar xvf rootfs_qtopia_qt4-20121108.tar.gz sudo mkyaffs2 rootfs_qtopia_qt4 rootfs_qtopia_qt4.img and copied to my microSD card and adjusted my `FriendlyARM.ini` to take this file instead of the MLC2 NAND flash version.
