Hi All, Please help me QT compilation for mini2440, following are the details: mkspecs/qws/linux-arm-g++/qmake.conf: include(../../common/g++.conf) include(../../common/linux.conf) include(../../common/qws.conf) # modifications to g++.conf QMAKE_CC = arm-v4t-linux-gnueabi-gcc -msoft-float -D__GCC_FLOAT_NOT_NEEDED -march=armv4t -mtune=arm920t -O0 -lts QMAKE_CXX = arm-v4t-linux-gnueabi-g++ -msoft-float -D__GCC_FLOAT_NOT_NEEDED -march=armv4t -mtune=arm920t -O0 -lts QMAKE_LINK = arm-v4t-linux-gnueabi-g++ -msoft-float -D__GCC_FLOAT_NOT_NEEDED -march=armv4t -mtune=arm920t -O0 -lts QMAKE_LINK_SHLIB = arm-v4t-linux-gnueabi-g++ -msoft-float -D__GCC_FLOAT_NOT_NEEDED -march=armv4t -mtune=arm920t -O0 -lts #modifications to linux.conf QMAKE_AR= arm-v4t-linux-gnueabi-ar cqs QMAKE_OBJCOPY = arm-v4t-linux-gnueabi-objcopy QMAKE_STRIP= arm-v4t-linux-gnueabi-strip QMAKE_RANLIB = arm-v4t-linux-gnueabi-ranlib QMAKE_INCDIR += /usr/local/comp-tslib/include/ QMAKE_LIBDIR += /usr/local/comp-tslib/lib/ QMAKE_CFLAGS_RELEASE += -march=armv4 -mtune=arm920t QMAKE_CFLAGS_DEBUG += -march=armv4t -mtune=arm920t QMAKE_CFLAGS_MT += -march=armv4t -mtune=arm920t QMAKE_CFLAGS_MT_DBG += -march=armv4t -mtune=arm920t QMAKE_CFLAGS_MT_DLL += -march=armv4t -mtune=arm920t QMAKE_CFLAGS_MT_DLLDBG += -march=armv4t -mtune=arm920t QMAKE_CFLAGS_SHLIB += -march=armv4t -mtune=arm920t QMAKE_CFLAGS_THREAD += -march=armv4t -mtune=arm920t QMAKE_CFLAGS_WARN_OFF += -march=armv4t -mtune=arm920t QMAKE_CFLAGS_WARN_ON += -march=armv4t -mtune=arm920t QMAKE_CXXFLAGS_DEBUG += -march=armv4t -mtune=arm920t QMAKE_CXXFLAGS_MT += -march=armv4t -mtune=arm920t QMAKE_CXXFLAGS_MT_DBG += -march=armv4t -mtune=arm920t QMAKE_CXXFLAGS_MT_DLL += -march=armv4t -mtune=arm920t QMAKE_CXXFLAGS_MT_DLLDBG += -march=armv4t -mtune=arm920t QMAKE_CXXFLAGS_RELEASE += -march=armv4t -mtune=arm920t QMAKE_CXXFLAGS_SHLIB += -march=armv4t -mtune=arm920t QMAKE_CXXFLAGS_THREAD += -march=armv4t -mtune=arm920t QMAKE_CXXFLAGS_WARN_OFF += -march=armv4t -mtune=arm920t QMAKE_CXXFLAGS_WARN_ON += -march=armv4t -mtune=arm920t load(qt_config) QT Source: qt-everywhere-opensource-src-4.7.0-tp tslib compiled output @ /usr/local/comp-tslib/ ls -lh /usr/local/comp-tslib total 16K drwxrwxrwx 2 root root 4.0K Jan 15 13:34 bin drwxrwxrwx 2 root root 4.0K Jan 15 13:34 etc drwxrwxrwx 2 root root 4.0K Jan 15 13:34 include drwxrwxrwx 4 root root 4.0K Jan 15 13:34 lib Command to comiple: $./configure -embedded arm -xplatform qws/linux-arm-g++ -prefix /usr/local/Qt -qt-mouse-tslib -little-endian -no-webkit -no-qt3support -no-cups -no-largefile -optimized-qmake -no-openssl -nomake tools -qt-sql-sqlite -no-3dnow -system-zlib -qt-gif -qt-libtiff -qt-libpng -qt-libmng -qt-libjpeg -no-opengl -gtkstyle -no-openvg -no-xshape -no-xsync -no-xrandr -qt-freetype -qt-gfx-linuxfb -qt-kbd-tty -qt-kbd-linuxinput -qt-mouse-tslib -qt-mouse-linuxinput Error: Creating qmake. Please wait... make: Nothing to be done for `first'. The tslib functionality test failed! You might need to modify the include and library search paths by editing QMAKE_INCDIR and QMAKE_LIBDIR in /home/zahir/Desktop/QT/qt-everywhere-opensource-src-4.7.0-tp/mkspecs/qws/linux- arm-g++. Please help me with it. i am struggling with this for a week. any help will be appreciated. Thanks, Dhruv
QT Error: The tslib functionality test failed!
Have you read the tutorial at mini2440vietnam? You have cross-compiled tslib first? And searched this site for: tslib functionality test failed
I tried qt compilation with diff versions, but still i am receiving the same error. can any one please help me on this. Downloading qt src from: http://ftp.jaist.ac.jp/pub/qtproject/archive/qt/4.6/ ARM Toolchain: OSELAS.Toolchain-2011.11.1/arm-v4t-linux-gnueabi/gcc-4.6.2-glibc-2.14.1-binutils -2.21.1a-kernel-2.6.39-sanitized/bin/arm-v4t-linux-gnueabi-
It seems you are using our toolchain but not our Mini2440 BSP. In the BSP compilation of Qt and tslib is already solved. Why do you try it to do by your own again?
@Juergen: I am only using toolchain of OSELAS.
I managed to compile QT. it was permission issues wrt tslib.
But stuck in other issue:
/mnt/demos/embedded/fluidlauncher # ./fluidlauncher -qws
./fluidlauncher: error while loading shared libraries: libts-1.0.so.0:
cannot open shared object file: No such file or directory
Followed all the steps from below link:
http://mini2440vietnam.blogspot.in/2011/04/upgrade-qt462-in-mini2440.html
I ran chmod 777 for /usr/local/tslib in order to ensure if its wrt
permission issues.
Please help me...
"cannot open shared object file: No such file or directory" Seems you forget to copy the ts-lib to your target.
@Juergen: As is said in pervious post that "I ran chmod 777 for /usr/local/tslib in order to ensure if its wrt permission issues." by which i meant those lib n permission i have cross checked :)
./fluidlauncher: error while loading shared libraries: libts-1.0.so.0: cannot open shared object file: No such file or directory Just a thought ... I recall that forum members bluscape or ruben had sorted out an error similar to this in Qt previous posts. Think it was ruben that came up with the answer. I think in response to: You might need to modify the include and library search paths by editing QMAKE_INCDIR and QMAKE_LIBDIR in Sorry, my Linux stuff is in another location.
The one I am referring to: http://www.friendlyarm.net/forum/topic/4853 Another related issue: http://www.friendlyarm.net/forum/topic/5488
Thanks davef. Issue resolved and able to run qt app, as there was problem with my RFS, due to which the lib path were nt exported properly.
