dear all i made a one gpio driver and i connect this gpio with 74hc541 buffer ic . when i boot the board , board can not start and when i remover gpio connector from buffer ic and do reset then board start. and after that when i connect again gpio connector to buffer ic it is completly working. then what is problem at starting??? anyone can help? thanks Ravi karavadiya
board not start when gpio connect with buffre 74HC541
Might help to post your GPIO driver code and the schematic of your buffer IC. I'll take a wild guess ... is the presence of the buffer detected somehow by the system? Chip select or an enable line?
