Hello, Very frustrating problem with the newer mini2440!!! Using a completely fresh install of the Platform builder with appropriate roll-ups, i have re attempted getting the Superboot working with the latest BSPs. I have tried compiling up a fresh build with no changes other than setting the options.h file to use the LCD_A70 instead of the default LCD_P43. The full build works without errors and produces the NK.BIN file. I have Superboot-2440 V1.3a on my board, with the friendlyarm.ini file as follows: <snip> #This line cannot be removed. by FriendlyARM(www.arm9.net) USBMode = No Action = Install OS = wince6 VerifyNandWrite = Yes LowFormat = No Status Type = Beeper| LED # Windows CE 6 part WindowsCE6-Bootloader = wince6/en/nboot_A70.bin WindowsCE6-BootLogo = wince6/bootlogo.bmp WindowsCE6-InstallImage = wince6/en/NK.bin <snip> Here is what happens: 1-move switch to NOR, insert SDHC card, power up 2-program all installs correctly with the following messages: <snip> Superboot-2440 V1.3a(20131213) by FriendlyARM Booting from NOR Try to find SD card.... Found. Installing bootloader... Installing bootloader succeed Installing bootloader succeed Installing CE Logo... Width, Height, BPP is 240 320 24 Logo Saved Installing CE Logo succeed Installing NK.bin... Unpacking NK.bin... Unpacked NK.bin Finished Installing unpacked NK.bin... Skip block 0x41 Installing NK.bin succeed Installing Windows CE 6 succeed <snip> 3-move switch to NAND, reset or power up, the WinCE6 environment powers up for the first time no problems. 4-power off the mini2440 and then power back on - the yellow progress bar moves to the right and hangs right there. (This is a HUGE problem right now and i cannot get further than this) I have also tried using the latest BSP (Mini2440-CE6-Suite-20141011) and it will NOT BUILD cleanly. I have also tried using the following in my friendlyarm.ini file in order to try Superboot2440.bin: <snip> #This line cannot be removed. by FriendlyARM(www.arm9.net) USBMode = No Action = Install OS = wince6 VerifyNandWrite = Yes LowFormat = No Status Type = Beeper| LED # Windows CE 6 part WindowsCE6-Bootloader = Superboot2440.bin WindowsCE6-BootLogo = wince6/bootlogo.bmp WindowsCE6-InstallImage = wince6/en/NK.bin #WindowsCE6-runImage = wince6/en/NK.bin <snip> when i try the same sequence as above, it also works the very first time, but when i try to power up a second time, i get a continuing reset problem like this: <snip> Superboot-2440 V1.3a(20131213) by FriendlyARM Booting from NAND Launch Windows CE... undefined instruction pc : [<0000009c>] lr : [<33f96c70>] sp : 33f3dbe4 ip : 30200000 fp : 00000000 r10: c02ab5bc r9 : 00000064 r8 : 33f3ffe0 r7 : 00000000 r6 : 33fa7654 r5 : 00000001 r4 : 30200000 r3 : 00000000 r2 : 00000000 r1 : 00000005 r0 : 4c000014 Flags: NzCv IRQs on FIQs on Mode USER_32 Resetting CPU ... resetting ... Superboot-2440 V1.3a(20131213) by FriendlyARM Booting from NAND Launch Windows CE... undefined instruction pc : [<0000009c>] lr : [<33f96c70>] sp : 33f3dbe4 ip : 30200000 fp : 00000000 r10: c02ab5bc r9 : 00000064 r8 : 33f3ffe0 r7 : 00000000 r6 : 33fa7654 r5 : 00000001 r4 : 30200000 r3 : 00000000 r2 : 00000000 r1 : 00000005 r0 : 4c000014 Flags: NzCv IRQs on FIQs on Mode USER_32 Resetting CPU ... resetting ... <snip> So as it stands right now i am completely stuck with this Superboot problem. I have waded through a lot of the topics in here and in the WinCE folder on the forum and have not seen any resolution to this problem. Does anyone have any solution? I have also tried the stock images from the CD rom and they also do the very same thing. ANY HELP WOULD BE APPRECIATED!!! Best regards, tkr
WinCE6 Superboot resolution?
UPDATE on this problem... This was a comedy of errors, but the ultimate source of the solution came down to this (in case anyone else runs into it): System: -Fresh Virtualbox with 32 bit Win7 install -Fresh Install of Platform builder and required updates -Microsoft security essentials running 2440 System: -2440 -A70 LCD with touchscreen The above problem was due to my supplier getting me an older copy of the BSP (which was equivalent to the xxx-Suite-1226 BSP). Once i switched to the 1401 BSP or the 20141011 BSP (which are identical BTW), i ended up with a build error. After reviewing some of the forum articles and noticing something on the virus scanner, i TURNED OFF real time protection on Microsoft Security Essentials. This allowed the build to complete without errors and i was able to use BOTH bootloaders (NBOOT_A70 and Superboot2440) Once built with the latest BSP, the system would boot for a second time. The primary change in the BSPs is in FMD.cpp old BSP (line 67): #define KEEP_BLOCKS (19) new BSP (line 67): #define KEEP_BLOCKS (19 + (32 * 1024 * 1024) / (128 * 1024)) the other changes were in bak_hw.cpp/h, bak_io.cpp, and s3c2440a_lcd.h all having to do with backlight changes and new LCD support. Needless to say, all is back operational at this point. trialsrideraz
Hi trialsrideraz: I am having same problem with new mini2440 with old Win CE image we used before successfully. It boots fine first time but not second time. It hang after progress bar is finished. I was using superboot_2440 and nboot_w35. Where did you get this new BSP?
