Hi, I'm following this blog: http://linux-dvbh.blogspot.com/2006/12/tslib-download-and-cross-compile-... I'm getting problems when I'm running autoconf: .../tslib$ sh autogen.sh Can't exec "libtoolize": No such file or directory at /usr/bin/autoreconf line 190. Use of uninitialized value $libtoolize in pattern match (m//) at /usr/bin/autoreconf line 190. configure.ac:25: error: possibly undefined macro: AC_DISABLE_STATIC If this token and others are legitimate, please use m4_pattern_allow. See the Autoconf documentation. configure.ac:26: error: possibly undefined macro: AC_ENABLE_SHARED configure.ac:27: error: possibly undefined macro: AC_LIBTOOL_DLOPEN configure.ac:28: error: possibly undefined macro: AC_PROG_LIBTOOL autoreconf: /usr/bin/autoconf failed with exit status: 1 I can't find the solution anywhere... I'm confused. I'm running Ubuntu 9.10 and I'm working on a mini2440 with Linux
tslib problems
Oh I feel so silly.. I found the solution already. :) I just had to do "sudo apt-get install libtool" to get the libtool package, now autoconf works..
sudo PATH=/Cross/Compiler/ARM/bin:$PATH ./configure --host=arm-angstrom-linux-gnueabi --prefix=/usr/local/tslib --enable-static --enable-shared sudo PATH=/Cross/Compiler/ARM/bin:$PATH make sudo PATH=/Cross/Compiler/ARM/bin:$PATH make install
