I got Fresh board mini2440. When I start the board having switch to NOR side.. I got following output... It hangs up on this output... Please guys tell me how can I get the promp... Superboot-2440 V1.3a(20131213) by FriendlyARM Booting from NOR Try to find SD card...... not found. Hello USB Loop
mini2440: superboot hangs on NOR
Superboot is a bootloader which can flash Nand Flash with Minitools(PC) and can flash the images into Nand Flash from SDCARD. "Hello USB Loop" is means that the superboot is work on Minitools model, you can run Minitools on PC, then you can see something.
Thanks for the reply... I have tried with minitools... But it is Chinese version... It shows green light indication, which means now it is connected with USB driver.. But what can I do next, hence there is no buttons or command prompt I can see... If you can suggest download location of English version of minitools then it will really help me...
i had also this problem with the superboot boot loader . but i updated this boot loader to "SUPERVIVI" , now it is working nice . so i can suggest you to just change you boot loader to supervivi . that's it.
Hi guy, i have the same problem with Chetan Dadhaniya, when i start kit with mini com by :"sudo minicom /dev/ttyUSB0 it can open supervivi in linux just always :" Superboot-2440 V1.3a(20131213) by FriendlyARM Booting from NOR Try to find SD card...... not found. Hello USB Loop " On the other hand, if i load kit with nand flash it just :"Freeing init memory: 156K hwclock: settimeofday() failed: Invalid argument [01/Jan/1970:00:00:14 +0000] boa: server version Boa/0.94.13 [01/Jan/1970:00:00:14 +0000] boa: server built Jul 26 2010 at 15:58:29. [01/Jan/1970:00:00:14 +0000] boa: starting server pid=690, port 80 Try to bring eth0 interface up......ifconfig: SIOCGIFFLAGS: No such device ifconfig: SIOCSIFHWADDR: No such device ifconfig: SIOCSIFADDR: No such device route: SIOCADDRT: Network is unreachable Done Please press Enter to activate this console. " i need to open Friendly arm bios 2.0 for 2440, plzz help me to open it :( tksssss so much
