Dear Friends, I got the mini2440 board with superboot in NOR... When I start the board by setting the switch on NAND side I got the prompt MINI2440 # I have loaded uboot,zImage & file system... after modifying environment variables I am able to run the Linux I have loaded... But when I restart the board environment variables changed... means saveenv command does not saves it permanently.. I read some where in forum that "dynpart + dynenv" command will work.. but I my case It does not solved the problem... This is Output of dynpart MINI2440 # dynpart mtdparts mtdparts=mini2440-nand:0x00040000(u-boot),0x00020000(u-boot_env),0x00200000(kern el),0x000a0000(splash),0x03d1c000(rootfs) nand0: partition (rootfs) size alignment incorrect nand0: partition (rootfs) size alignment incorrect nand0: partition (rootfs) size alignment incorrect nand0: partition (rootfs) size alignment incorrect nand0: partition (rootfs) size alignment incorrect Please guys Point me where I am wrong...
saveenv not working
I have used u-boot128.bin supplied in DVD. Is it the problem with bootloader... (setenv might be disabled before compilation)...? Please guys...
