I am using arm mini 6410. I tried to install opencv several times but it failed. I followed the steps given in opencv documentation. http://docs.opencv.org/doc/tutorials/introduction/crosscompilation/arm_c... The following error appears- [root@localhost opencv-2.4.10]# cmake -DCMAKE_TOOLCHAIN_FILE=/opencv/opencv-2.4.10/platforms/linux/arm-gnueabi.toolcha in.cmake /opencv/opencv-2.4.10/ -- The CXX compiler identification is unknown -- The C compiler identification is unknown -- Check for working CXX compiler: arm-linux-gnueabihf-g++-4.6 CMake Error: your CXX compiler: "arm-linux-gnueabihf-g++-4.6" was not found. Please set CMAKE_CXX_COMPILER to a valid compiler path or name. CMake Error: Internal CMake error, TryCompile configure of cmake failed -- Check for working CXX compiler: arm-linux-gnueabihf-g++-4.6 -- broken CMake Error at /usr/share/cmake/Modules/CMakeTestCXXCompiler.cmake:54 (message): The C++ compiler "arm-linux-gnueabihf-g++-4.6" is not able to compile a simple test program. It fails with the following output: CMake will not be able to correctly generate this project. Call Stack (most recent call first): CMakeLists.txt:56 (project) CMake Error: your CXX compiler: "arm-linux-gnueabihf-g++-4.6" was not found. Please set CMAKE_CXX_COMPILER to a valid compiler path or name. CMake Error: your C compiler: "arm-linux-gnueabihf-gcc-4.6" was not found. Please set CMAKE_C_COMPILER to a valid compiler path or name. -- Configuring incomplete, errors occurred! I specified CMAKE_C_COMPILER and CMAKE_CXX_COMPILER environment variables to /opt/FriendlyARM/toolschain/4.5.1/bin/arm-linux-gcc and arm-linux-g++ respectively but it didn't work. Does that mean that it works only with arm-linux-gcc-4.6? Can someone please help me?
installing opencv
All I can suggest are a few hints as I have not done this before: - does the mini6410 support hardware floating point? - have you checked that make (cmake in your case) can actually find the compiler? - are you sure the directory is called ../toolschain/... looks misspelt to me This procedure sounds like you end up with OpenCV to run on some generic ARM based platform. I guess you are trying to modify it to work for the mini6410. Can I assume you have checked the 5 pages of hits on this site and the 24,500 hits on Google? Good luck!
