Hi Everyone, Hope you guys are doing well. I'm trying to build common_android_kernel-3.10 on mini2440(x35). Did configuration by merging three configuration (mini2440_defconfig, android-base.cfg and config_mini2440_x35) files using scripts/kconfig/merge_config.sh. Got zImage successfully, without any errors. PROBLEM: Problem is not able to see kernel messages on my pc. I'm using ttyUSB0 serial cable with minicom tool. Did changes changes on default kernel command line options as console=ttySAC0,115200. Not able to find the solution. I would be thankful if anyone helps me.
SERIAL_CONSOLE PROBLEM ON COMMON_ANDROID_KERNEL-3.10
I got the same problem on 3.10. there is a bug about UART clock on 3.10. here: https://github.com/torvalds/linux/commit/ee2f769fb4a5a317b1558d0bbcccb89... after 3.10.4, they fixed this bug. by the way, if there is nothing kernel messages, you can enable CONFIG_DEBUG_LL see some low debug message. menuconfig ---> Kernel hacking ---> [*] Kernel debugging [*] Kernel low-level debugging functions (read help!) Kernel low-level debugging port (Use S3C UART 0 for low-level debug) --->
Supplement: After enable CONFIG_DEBUG_LL, I can't get this kernel message: "Warning: Neither atags nor dtb found" which is print with func "early_print", It can works fine than prink. so I find the bug from git log. finally, I use the 3.10.4, UART can works fine. hope helpful to you. :P
Sorry, there is a wrong spelling. Supplement: After enable CONFIG_DEBUG_LL, I *can get this kernel message: "Warning: Neither atags nor dtb found" which is print with func "early_print", It can works fine than prink. so I find the bug (about UART clock) from mainline kernel git log. finally, I use the 3.10.4, UART can works fine. hope helpful to you. :P
Hi vicky. with 3.10.4, I can't get any voice. have you tried this? and can you give me some advice ? but with 3.12, I can get voice. And I'm trying to modify 3.10.4 to MINI2440, there is the GIT repo: https://github.com/kangear/linux/commits/mini2440/v3.10.4_modify Maybe we do it together. :)
Hi kangear. Hope you doing good. I'm very sorry to say that I didn't try voice. I'm trying to bring up android on mini2440 with 'android kernel 3.10', using boot loader: 'supervivi128M' and I downloaded file system from http://www.friendlyarm.net/forum/topic/5458 Modified file system as ext3 format using 'mkext3image' binary file. Passed command line arguments as 'noinitrd root=/dev/mtdblock2 init=/linuxrc console=ttySAC0,115200' PROBLEM: Getting errors No soundcards found. end_request: I/O error, dev mtdblock2, sector 2 EXT3-fs (mtdblock2): error: unable to read superblock end_request: I/O error, dev mtdblock2, sector 2 EXT4-fs (mtdblock2): unable to read superblock end_request: I/O error, dev mtdblock2, sector 2 EXT4-fs (mtdblock2): unable to read superblock FAT-fs (mtdblock2): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive! __nand_correct_data: uncorrectable ECC error end_request: I/O error, dev mtdblock2, sector 0 FAT-fs (mtdblock2): unable to read boot sector VFS: Cannot open root device "mtdblock2" or unknown-block(31,2): error -5 Please append a correct "root=" boot option; here are the available partitions: 1f00 256 mtdblock0 (driver?) 1f01 128 mtdblock1 (driver?) 1f02 5120 mtdblock2 (driver?) 1f03 1043072 mtdblock3 (driver?) Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,2) CPU: 0 PID: 1 Comm: swapper Not tainted 3.10.0-FriendlyARM #17 Backtrace: [<c0012248>] (dump_backtrace+0x0/0x10c) from [<c001245c>] (show_stack+0x18/0x1c) r6:c04a9510 r5:00008001 r4:c042fdf0 r3:00000000 [<c0012444>] (show_stack+0x0/0x1c) from [<c037a260>] (dump_stack+0x20/0x28) [<c037a240>] (dump_stack+0x0/0x28) from [<c0377868>] (panic+0x88/0x1d0) [<c03777e0>] (panic+0x0/0x1d0) from [<c048dd50>] (mount_block_root+0x1c4/0x270) r3:00000001 r2:00000000 r1:c0837ea0 r0:c042fdf0 r7:c042fe58 [<c048db8c>] (mount_block_root+0x0/0x270) from [<c048dfe4>] (mount_root+0xec/0x114) [<c048def8>] (mount_root+0x0/0x114) from [<c048e16c>] (prepare_namespace+0x160/0x1b4) r8:c04a94e8 r7:c04e9ea0 r6:c04a9510 r5:c04a9510 r4:c04e9f00 [<c048e00c>] (prepare_namespace+0x0/0x1b4) from [<c048d948>] (kernel_init_freeable+0x16c/0x1b0) r6:c04e9ea0 r5:00000007 r4:c04af86c [<c048d7dc>] (kernel_init_freeable+0x0/0x1b0) from [<c037671c>] (kernel_init+0x10/0x158) [<c037670c>] (kernel_init+0x0/0x158) from [<c000ec10>] (ret_from_fork+0x14/0x24) r5:c037670c r4:00000000 Hope you can give advices to me, if you don't mind. Email Id: vikramp1991@gmail.com
Hi vicky. there are some advice for you. 1.add "rootfstype=ext3" in command line, and try it. 2.actually, I didn't try ext3 filesystem on Mini2440, I only tried Yaffs2. If there still are some problem, maybe you can try Yaffs2 filesystem. 3.I guess that maybe you flash the rootfs(ext3) use flash yaffs2 fs way. so ...
Dear kangear, Thanks for your response. 1. I tried by passing 'rootfstype=ext3' in command line. But still getting Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,2). 2. And also I tried with 'initramfs'. This time I'm getting error : Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b 3. I tried yaffs2 file system. Created yaffs2 file system using 'mkyaffs2image-128M'. I found that there is no supported configuration for yaffs2 file system in android kernel 3.10. Can you share where I need to change kernel source code or where can I find default supported yaffs2 file system android kernel. Please share info through mail, if you don't mind. Email Id: vikramp1991@gmail.com Thanks.
Hi kangear, Got yaffs2 file system patches from: https://github.com/kangear/linux/commit/089b3744d9605814b48d4754eea6d2a6... Mounted file system successfully. Now I'm able to activate console (Please press Enter to activate this console) on my pc through serial cable and also able to see bootup logo (penguin). PROBLEM: Not able to see graphics on board. Please share info, if you are aware.
Hi vicky. congrats you for mounting rootfs successfully. And I'm sorry that I am not very clear to your LAST PROBLEM. Can you describe some of the more clearly it?
Hi kangear... Problem is "Not able to see any applications on board". Using 2.6.27 android kernel I'm able to see applications as like below video shows. You can find video here: https://www.youtube.com/watch?v=ouaKNhytEdo I'm trying to bring up the board as like above video shows, using common android kernel 3.10 and yaffs2 file system. For that I did configuration by merging three configuration (mini2440_defconfig, android-base.cfg and config_mini2440_x35) files using scripts/kconfig/merge_config.sh. I think there are lot of changes happened in between android kernel 2.6 and android kernel 3.10 according to android changes, and file systems too. I'm not aware how to fix these issues. Can you advice me where can I find default android kernel configuration file (or kernel image) and android file system. Hope you understood clearly. Thanks for your response.
Hi, vicky Yes, I'm clear now. But I haven't try Linux _3.10_ for Android on Mini2440. So, I can't advice something about __3.10__. BTW,I had tried the android image (kernel and filesystem) which was provided by FriendlyARM on Mini2440. Images is here: http://www.arm9.net/download.asp (Chinese) And there are some pictures I took. http://www.arm9home.net/read.php?tid=27499 (Chinese) Enjoy it. :)
