Hi, I have a problem building BSP from Mini2440-CE6-Suite-20141011. During Sysgen it says Could not find file C:\WINCE600\OSDesigns\Mini2440-en\Mini2440-en\RelDir\Mini2440_ARMV4I_Release\oal .exe on disk. I checked where the file should be copied from. It should be built in C:\WINCE600\PLATFORM\Mini2440\target\ArmV4I\retail\. However, there is no directory \target under C:\WINCE600\PLATFORM\Mini2440. Obviously something goes very wrong and this dir doesn't get created, but where? How do I fix it? I have disabled antivirus so this is not the cause of the failure. Any ideas?
Could not find file oal.exe
And22, I also had the same problem. The latest Suite from 20141011 will not build properly - even with a fresh install of the Platform builder and all updates required. I had to go back to an earlier Suite to get it to build. Best regards, trialsrideraz
And22, mine worked after disabling Microsoft Security Essentials real time protection. full build worked fine. best regards, trialsrideraz
Hi Abuda, You can download it www.friendlyarm.com/download, this version is newest. If when you build wince image fail i suggest you should delete old wince bsp then you install a new bsp above. Best Gg.
