could anyone can tell me how can i run 2 individual c program in ARM terminal window from my host computer ....??? here i can't open 2 separate terminals of ARM board because i am using serial port to see the ARM file system . so once i run a ./a.out program , it keeps blocking the terminal window till the end of the prog execution . so i could not run my 2nd program . plz tell me the proper way of executing multiple process on embedded board ..
how to run 2 separate programs in MINI2440 terminal
hi sushant this method of execution of program works on pc linux terminal but it is not working in friendly ARM board . i tried this method before . there is even very big problem came when i executed the program using ./a.out & . the problem was like neither the program run in background nor i could stopped it . i could not even stopped using ctrl+c key . i had to reboot my board that time . i think there would be some other techniques for this issue. so plz let me know if any other method we have ....
hello sushant , could you plz give me your mail id ? i will sent you the screen shot to your mail id . thanks
