Extending 4.3" LCD cable
geophysics4
Hardware question here - we are trying to integrate a Mini210 into a new
geophysical instrument.  The SBC itself must be mounted on a backpack, but
we need a display (touchscreen) to be wrist mounted.  Not only do we need
the display waterproof (another problem!), but we need to run a 1 meter (3
foot) cable from the backpack to the LCD.  Any suggestions on this?  The
standard 40-pin connectors are far too short.
Thanks!
maciek
Your problem is not short 40 pin tft cable. Your problems are interference
and many other "sh*t" in ether.
Look for transceiver maybe something like LVDS or maybe VGA. 1m VGA should
be resonable solution, cable with some ferrite of course. Touch by "normal"
interface i2c, if some ghost touch will appear then make i2c to rs485 on
some small board, spi the same solution.
Remember even if u make it with VGA and something wrong will start then u
have to look for differential type data transfer, so first solution
RGB->LVDS.
Oh , I almost forgot i2c can be in very simple way made as differential
signal.
Waterproof is not a problem put display in waterproof box and let cables by
some muffs. Touchscreen hmm , you have to give information how big
resolution for touch u need - less resolution less problem, Big resolution
expensive problem.
Good luck.
