No O/P from mini2440 in NOR flash mode
Anil Kumar
   I have connected a mini2440 (ARM 9 Kit with TFT) to my Ubuntu 14.x based
Linux machine via a USB-Serial cable. When I switch to NOR Flash boot mode,
I get no output on the terminal window. I have tried using putty and screen
setting the baud rate to 115200 and flow control to None.
   Can someone tell if anything could be wrong ? Help appreciated.
Thanks,
Anil
Do you know the history of this machine?
I use minicom for this purpose, I imagine you have Putty setup to receive
on the correct comm port.
If nothing shows up you may have to JTAG your bootloader back into NOR.
http://www.andahammer.com/assets/Uploads/All2440/Firmware/JTAGingTheNOR.pdf
Everybody should do this at least once!
While you are at this stage you might want to change from SuperVivi to
Superboot.  There are quite a few threads about <mini2440 Superboot>.
I haven't done this, so I don't know how the change is made.
