Hello I wonder if anyone can advice to a problem I've had for some time with DNW.exe. I'm trying to restore the image on a satnav that uses the S3C2443XL-40 Arm chip. I'm trying to transfer an winceimg.bin and a region.bin file to restore the image. I can use usb (no com port)only and transmit the file direct from the DNW usb transmit. The problem that I have is that I as far as I can tell I can only transmit the one file at a time on USB. The unit is looking for both files to be loaded simultaneously. Therefore the most I can do is load the winceimg.bin and the region info is missing. On units with a built in SD card (which this has not) both files are simply placed on the card and are loaded up automatically. The question is whether there is a method of selecting or loading more than one file with DNW. I have tried multiple keyboard selections and none seen to highlight more than one file. Any of the ARM experts have experiance of this ?
