Mini2440 P35
Sundeep
The Mini2440 Boards with P35 LCD Touchscreen are getting problem when when
insert a SD Card into the slot. The touch is stopped working...same with 3
boards.What is the problem with it?
What is the solution in order to make SD card as well as touch screen work?
cowboy
Hi, There is Similar question and answer as follow:
i've been running gentoo on a mini2440, it's a arm powered
development-board. Gentoo is running from a 2 GB Sd-Card.
First thing is the place on the sd-card.
the Full content see below url:
http://www.hycshop.com/article/mini2440_SD_problem.htm
sundeep
@cowboy
I think u have not got the problem..i am not facing problem in loading the
OS, but the problem is with touch screen P35. Whenever we insert a SD card
the touch screen stops working...even in new boards also..have any one
faced this problem?
