FriendlyARM.ini #This line cannot be removed. by FriendlyARM(www.arm9.net) CheckOneButton=No Action = Install OS = Android LCD-Mode = No LCD-Type = H43 LowFormat = Yes VerifyNandWrite = No CheckCRC32=No StatusType = Beeper | LED ################### Android 4.0.3 #################### Android-BootLoader = Superboot210.bin Android-Kernel = Android/zImage Android-CommandLine = root=/dev/mtdblock4 console=ttySAC0,115200 init=/linuxrc androidboot.console=ttySAC0 skipcali=yes ctp=3 Android-RootFs-InstallImage = Android/rootfs_android.img Always ask me to calibrate the screen but does not respond. Any idea ? I have looked through the forum but did not solve the problem. Thank you
skipcal = yes don't work
I have a Mini210S and I use this config to install Android: #This line cannot be removed. by FriendlyARM(www.arm9.net) CheckOneButton=No Action = Install OS =Android LCD-Mode = No LCD-Type = S70 LowFormat = No VerifyNandWrite = No CheckCRC32=No StatusType = Beeper | LED ################### Android 4.0.3 #################### Android-BootLoader = Superboot210.bin Android-Kernel = Android/zImage Android-CommandLine = root=/dev/mtdblock4 rootfstype=yaffs2 console=ttySAC0,115200 init=/linuxrc androidboot.console=ttySAC0 skipcali=yes ctp=2 Android-RootFs-InstallImage = Android/rootfs_android.img You have to make sure your ctp command is correct.
