Hello all, I am trying to prepare an SD card with superboot with the Mini2451. I used the SD-flasher tool to fuse the superboot2451.bin file to the card. I also copied the contents of the images/ directory from the FriendlyARM DVD to the root of the SD, as described in the manual. After this I insert the SD card in the Mini2451, move the boot selector to the SD position and turn power on. I get a message on the console saying: Superboot-2451 V1.05a(20131223) by FriendlyARM Booting from SD But after this, nothing else. Any hints ?
Mini2451 superboot problem
I now have the same problem. Using the images, folder structure and friendlyarm.ini from the DVD. Superboot-2451 V1.06a(20141013) by FriendlyARM Booting from SD LEDs 2, 3 and 4 come on and then go out, only the power LED remains.
hello, you can download Mini2451-usersmanual , the manual has method of burning system . Mini2451-usersmanualV11292013-12092013 http://www.mediafire.com/view/il3qknzo5ndgwdq/Mini2451-usersmanualV11292...
If you have further problems feel free to my blog and contact with me http://mini2440arm.weebly.com/
I also have superboot problem.My platform is Tiny6410 + SDK board, When I boot from SD, UART shows "Booting from SD" only, then nothing happen. If I replace superboot with u-boot.bin in SD boot area.It will work fine. Then I change another SD card, but with same situation. I think it's not caused by SD card, and I Download other superboot.bin from FriendlyARM Web. but nothing changed. Could any one could help for fix this problem?
