Superboot-2440 V1.1(20130529) by FriendlyARM. . Try to find SD card.... Found.. after displaying this msg nothing happens . please any one help me regarding the booting process of mini2440 .
booting problem superboot
@ashwin u have load OS on to SD and Boot..if not convert the bootloader from superboot to supervivi.
hi sundeep thanks for your reply could you please tell me in detail how to convert the bootloader from superboot to supervivi.
Hello Ashwin, I would recommend you to use Supperboot. You can use MiniTools to load image file to board or copy "images" folder from Support DVD to SD Card and flash board very efficiently and easily. If you want to replace Superboot with Supervivi, then Search for "JTAGing the NOR.pdf" or "JTAG the NOR.pdf" (on Google and/or this forum). I have seen a tutorial for flashing NOR by "Dom" on "www.domodom.fr" I hope this will help.
thank you sandeep i tried as you said also refered www.domdom.fr but i am not getting the booting menu . i am getting the same msg as before . let me tell u what i had done during the process , if anything i did mistake plz let me know i had gone through the following steps 1. formatted the sd card with FAT32. 2. burned "Superboot2440.bin" file to sd card using sd flasher tool . 3. copied the "FriendlyARM.ini" file in /images/ directory in sd card . 4. then boot mini2440 board in NOR mode 5. got msg as below Superboot-2440 V1.1(20130529) by FriendlyARM. . Try to find SD card.... Found.. 6. the content of "FriendlyARM.ini" as below #This line cannot be removed. by FriendlyARM(www.arm9.net) USBMode = No Action = Install OS = Linux VerifyNandWrite = Yes LowFormat = No Status Type = Beeper| LED # Linux part Linux-BootLoader = Superboot2440.bin Linux-Kernel = Linux/zImage_W35 Linux-CommandLine = noinitrd root=/dev/mtdblock3 init=/linuxrc console=ttySAC0 Linux-RootFs-InstallImage = Linux/rootfs_qtopia_qt4.img # Windows CE 6 part WindowsCE6-Bootloader = wince6/nboot_W35.bin WindowsCE6-BootLogo = wince6/bootlogo.bmp WindowsCE6-InstallImage = wince6/NK_W35.bin #User Bin part UserBin-Bootloader = Superboot2440.bin UserBin-Image = 2440test/2440test_W35.bin userBinStartAddress=30000000
as I can see from your FriendlyARM.ini configuration file, you should have directory/file structure on SD card as follows: SD_card/images/FriendlyARM.ini SD_card/images/Superboot2440.bin SD_card/images/Linux/zImage_W35 SD_card/images/Linux/rootfs_qtopia_qt4.img
