1) SPI: I am trying to include SPI in mini2440 kernel, i have selected all the option in make menuconfig of kernel, even though there so SPI device is showing up in the "/dev folder of the board. Should i do anything more to show it up..where as some empty folder of spi_master and spidev have been created in "/sys/class/" area. SO please guide me how to display and write a simple program in Qt 2) I2c: Can anyone help a sample program to interface a I2C Device with Mini2440, i am trying to write the program in Qt creator. Any sample will help me a lot...thank you
Reg: SPI and I2C on Mini2440
I recently reposted a SPI kernel driver that I managed to get working with a test program. Try searching "SPI davef" The kernel still needs patching for mini2440 SPI ... I believe. Good luck!
Hi Dave No success,searched but cant find it..can u pls repost it here..also may i know how to patch it for mini2440 SPI..thanks
Hi Dave thanks..got the SPI driver for mini2440 doc by you..will try to implement it today...pls also provide any help over i2c as i have to interface both of the devices..thank you
An I2C driver will be in the kernel, similar to SPI. You might then write a program (application) in QtCreator to access the I2C.
Hi davef I have attached ds1621 to mini2440 and it is working fine with i2ctools. I got a kernel driver code for the ds1621.Can you pls help me with the step by step approach to build it? The file is attached here.
http://www.friendlyarm.net/forum/topic/6560 https://www.cyberciti.biz/faq/compiling-c-program-and-creating-executabl... These are for a user application. I'd look for "The Linux Module Programming Guide" and in Chapter 2 they talk about the differences and how to compile kernel modules. Good luck!
I have tried to build example hello.c for kernel following the "The Linux
Module Programming Guide" and in Chapter 2, but "make" gives following
error. can you please tell me what is wrong?
mou@mou-ubuntu:~/Downloads/Ex-Driver$ make -C
/home/mou/Downloads/linux-2.6.32.2/ M=$(PWD) helloPWD: command not found
make: Entering directory `/home/mou/Downloads/linux-2.6.32.2'
make: *** No rule to make target `hello'. Stop.
make: Leaving directory `/home/mou/Downloads/linux-2.6.32.2'
My make file is
obj−m := hello.o
all:
make −C /home/mou/Downloads/linux-2.6.32.2/ M=$(PWD) modules
clean:
make −C /home/mou/Downloads/linux-2.6.32.2/ M=$(PWD) clean
and the C file is
* hello−1.c − The simplest kernel module.
#include <linux/module.h>
/* Needed by all modules */
#include <linux/kernel.h>
/* Needed for KERN_INFO */
int init_module(void)
printk(KERN_INFO "Hello world 1.\n");
* A non 0 return means init_module failed; module can't be loaded.
return 0;
void cleanup_module(void)
printk(KERN_INFO "Goodbye world 1.\n");
From the 2nd link ... did you try: In terminal cd to the directory that has your hello.c file. (gcc program.c -o program-output) gcc hello.c -o hello Maybe it is a permissions problem with your procedure, ie: sudo make -C
It does not work since the hello is written for module, it is not finding
module.h
mou@mou-ubuntu:~/Downloads/Ex-Driver$ ls
hello.c Makefile Makefile~
mou@mou-ubuntu:~/Downloads/Ex-Driver$ sudo su
[sudo] password for mou:
bash: [: /etc/debian_chexport: binary operator expected
root@mou-ubuntu:/home/mou/Downloads/Ex-Driver# gcc hello.c -o hello
hello.c:5:26: fatal error: linux/module.h: No such file or directory
compilation terminated.
The simple hello.c as follows worked for me. I have tested it
#include <stdio.h>
int main()
printf("Hello World\n");
return 0;
First check that you have a module.h in your ../linux directory. Maybe, your project has to be in the directory above ../linux so that it can find module.h What is the full path to linux/module.h ?
Since I did this, years ago, I have had to re-install Ubuntu several times. So, I have forgotten the process. My thought is that where you issue your command: gcc hello.c -o hello has to have a path to your cross-compile toolchain and to where you have the kernel source. Or your project has to be in a place where it can find module.h But, first what do you get with: gcc -v
https://www.kernel.org/doc/Documentation/kbuild/modules.txt See 2.1 and 2.2 $ make -C <path_to_kernel_src> M=$PWD OK,further up I see you have a path to your kernel source but you got an error on that line. What do you get with the command: printenv
gcc -v gives followos mou@mou-ubuntu:~/Downloads/Ex-Driver$ gcc -v Using built-in specs. COLLECT_GCC=gcc COLLECT_LTO_WRAPPER=/usr/lib/gcc/i686-linux-gnu/4.6/lto-wrapper Target: i686-linux-gnu Configured with: ../src/configure -v --with-pkgversion='Ubuntu/Linaro 4.6.3-1ubuntu5' --with-bugurl=file:///usr/share/doc/gcc-4.6/README.Bugs --enable-languages=c,c++,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-4.6 --enable-shared --enable-linker-build-id --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.6 --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --enable-gnu-unique-object --enable-plugin --enable-objc-gc --enable-targets=all --disable-werror --with-arch-32=i686 --with-tune=generic --enable-checking=release --build=i686-linux-gnu --host=i686-linux-gnu --target=i686-linux-gnu Thread model: posix gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) mou@mou-ubuntu:~/Downloads/Ex-Driver$ and printenv gives mou@mou-ubuntu:~/Downloads/Ex-Driver$ printenv SSH_AGENT_PID=1302 GPG_AGENT_INFO=/tmp/keyring-SHD25S/gpg:0:1 TERM=xterm SHELL=/bin/bash XDG_SESSION_COOKIE=acb75566863010789e35b6ae0000000a-1486963937.343988-2092943809 WINDOWID=60825802 OLDPWD=/home/mou/Downloads GNOME_KEYRING_CONTROL=/tmp/keyring-SHD25S USER=mou LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd =40;33;01:or=40;31;01:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=0 1;32:*.tar=01;31:*.tgz=01;31:*.arj=01;31:*.taz=01;31:*.lzh=01;31:*.lzma=01;31:*. tlz=01;31:*.txz=01;31:*.zip=01;31:*.z=01;31:*.Z=01;31:*.dz=01;31:*.gz=01;31:*.lz =01;31:*.xz=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.d eb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31 :*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.jpg=01;35:*.jpeg=0 1;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.x bm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01; 35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mk v=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;3 5:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=0 1;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd =01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.axv=01;35:*.anx=01;35:*.ogv=01;35:* .ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.mid=00;36:*.midi=00;36:*.mka=00 ;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.axa=00;36:*.oga =00;36:*.spx=00;36:*.xspf=00;36: XDG_SESSION_PATH=/org/freedesktop/DisplayManager/Session0 XDG_SEAT_PATH=/org/freedesktop/DisplayManager/Seat0 SSH_AUTH_SOCK=/tmp/keyring-SHD25S/ssh SESSION_MANAGER=local/mou-ubuntu:@/tmp/.ICE-unix/1266,unix/mou-ubuntu:/tmp/.ICE- unix/1266 DEFAULTS_PATH=/usr/share/gconf/ubuntu.default.path XDG_CONFIG_DIRS=/etc/xdg/xdg-ubuntu:/etc/xdg PATH=/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin: /sbin:/bin:/usr/games:/home/mou/opt/FriendlyARM/toolschain/4.4.3/bin:/home/mou/l ocal/ptxdist-2015.01.0/bin DESKTOP_SESSION=ubuntu PWD=/home/mou/Downloads/Ex-Driver LANG=en_IN MANDATORY_PATH=/usr/share/gconf/ubuntu.mandatory.path UBUNTU_MENUPROXY=libappmenu.so COMPIZ_CONFIG_PROFILE=ubuntu GDMSESSION=ubuntu SHLVL=1 HOME=/home/mou LANGUAGE=en_IN:en GNOME_DESKTOP_SESSION_ID=this-is-deprecated LOGNAME=mou XDG_DATA_DIRS=/usr/share/ubuntu:/usr/share/gnome:/usr/local/share/:/usr/share/ DBUS_SESSION_BUS_ADDRESS=unix:abstract=/tmp/dbus-MxzgGn8oYJ,guid=305cd84cc1bfa94 16887b16e0000000e LESSOPEN=| /usr/bin/lesspipe %s DISPLAY=:0 XDG_CURRENT_DESKTOP=Unity LESSCLOSE=/usr/bin/lesspipe %s %s COLORTERM=gnome-terminal XAUTHORITY=/home/mou/.Xauthority _=/usr/bin/printenv mou@mou-ubuntu:~/Downloads/Ex-Driver$
Further up you appear to be cross-compiling with linux-2.6.32.2 gcc -v seems to be finding a toolchain for host computer and in printenv I don't see a path to linux-2.6.32.2 For the mini2440 you need to add a PATH to linux-2.6.32.2
Hi davef is this correct?? root@mou-ubuntu:/home/mou# arm-linux-gcc -v Using built-in specs. Target: arm-none-linux-gnueabi Configured with: /opt/FriendlyARM/mini2440/build-toolschain/working/src/gcc-4.4.3/configure --build=i386-build_redhat-linux-gnu --host=i386-build_redhat-linux-gnu --target=arm-none-linux-gnueabi --prefix=/opt/FriendlyARM/toolschain/4.4.3 --with-sysroot=/opt/FriendlyARM/toolschain/4.4.3/arm-none-linux-gnueabi//sys-roo t --enable-languages=c,c++ --disable-multilib --with-arch=armv4t --with-cpu=arm920t --with-tune=arm920t --with-float=soft --with-pkgversion=ctng-1.6.1 --disable-sjlj-exceptions --enable-__cxa_atexit --with-gmp=/opt/FriendlyARM/toolschain/4.4.3 --with-mpfr=/opt/FriendlyARM/toolschain/4.4.3 --with-ppl=/opt/FriendlyARM/toolschain/4.4.3 --with-cloog=/opt/FriendlyARM/toolschain/4.4.3 --with-mpc=/opt/FriendlyARM/toolschain/4.4.3 --with-local-prefix=/opt/FriendlyARM/toolschain/4.4.3/arm-none-linux-gnueabi//sy s-root --disable-nls --enable-threads=posix --enable-symvers=gnu --enable-c99 --enable-long-long --enable-target-optspace Thread model: posix gcc version 4.4.3 (ctng-1.6.1) root@mou-ubuntu:/home/mou# root@mou-ubuntu:/home/mou/Downloads/linux-2.6.32.2# printenv SHELL=/bin/bash TERM=xterm XDG_SESSION_COOKIE=acb75566863010789e35b6ae0000000a-1487332014.785431-1128254038 USER=root LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd =40;33;01:or=40;31;01:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=0 1;32:*.tar=01;31:*.tgz=01;31:*.arj=01;31:*.taz=01;31:*.lzh=01;31:*.lzma=01;31:*. tlz=01;31:*.txz=01;31:*.zip=01;31:*.z=01;31:*.Z=01;31:*.dz=01;31:*.gz=01;31:*.lz =01;31:*.xz=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.d eb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31 :*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.jpg=01;35:*.jpeg=0 1;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.x bm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01; 35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mk v=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;3 5:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=0 1;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd =01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.axv=01;35:*.anx=01;35:*.ogv=01;35:* .ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.mid=00;36:*.midi=00;36:*.mka=00 ;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.axa=00;36:*.oga =00;36:*.spx=00;36:*.xspf=00;36: SUDO_USER=mou SUDO_UID=1000 USERNAME=root MAIL=/var/mail/root PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/ho me/mou/opt/FriendlyARM/toolschain/4.4.3/bin:/home/mou/local/gawk-4.1.0:/home/mou /local/flex-2.5.39:/home/mou/Downloads/ncurses-5.7/lib:/home/mou/local/ptxdist-2 015.01.0/bin:/epics/base-3.14.12.4/bin/linux-x86:/home/mou/Downloads/qt-everywhe re-opensource-src-4.8.5/bin:/home/mou/Downloads/qt-everywhere-opensource-src-4.8 .5/lib EPICS_HOST_ARCH=linux-x86 PWD=/home/mou/Downloads/linux-2.6.32.2 LANG=en_IN SHLVL=1 SUDO_COMMAND=/bin/su HOME=/root LANGUAGE=en_IN:en LOGNAME=root LESSOPEN=| /usr/bin/lesspipe %s SUDO_GID=1000 DISPLAY=:0 LESSCLOSE=/usr/bin/lesspipe %s %s XAUTHORITY=/home/mou/.Xauthority COLORTERM=gnome-terminal _=/usr/bin/printenv OLDPWD=/home/mou/Downloads root@mou-ubuntu:/home/mou/Downloads/linux-2.6.32.2# and I found module.h in root@mou-ubuntu:/home/mou/Downloads/linux-2.6.32.2/include/linux# Now what to do?
No. Configured with: /opt/FriendlyARM/mini2440/build-toolschain/working/src/gcc-4.4.3/configure Wrong toolchain PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/ho me/mou/opt/FriendlyARM/toolschain/4.4.3/bin:/home/mou/local/gawk-4.1.0:/home/mou /local/flex-2.5.39:/home/mou/Downloads/ncurses-5.7/lib:/home/mou/local/ptxdist-2 015.01.0/bin:/epics/base-3.14.12.4/bin/linux-x86:/home/mou/Downloads/qt-everywhe re-opensource-src-4.8.5/bin:/home/mou/Downloads/qt-everywhere-opensource-src-4.8 .5/lib **** Still don't see a path to your 2.6.32.2 toolchain. You have paths to several toolchains, how did you set those up?
