Hi, I'm looking at Reggie's port of Barebox for Mini210s. I'd like to boot over TFTP with it. When I use it to TFTP the kernel, it starts to download and at some point, it says "out of memory" mini210:/ tftp zImage [###############################################################write: O ut of memory If I use Pengutronix BSP for mini2440, TFTP works fine. Barebox's version then is 2011.05.0 If I try to use barebox's last version (2014.08.0), I get the same issue : mini2440:/ tftp zImage [###############################################################write: O ut of memory I noticed the malloc space is different between those two versions of barebox, I don't know if it can be the root cause PTX : Malloc space: 0x33a00000 -> 0x33e00000 (size 4 MB) Last : malloc space: 0x31bf8000 -> 0x31ff7fff (size 4 MiB) I'd like to understand what makes mini2440 booting fine over TFTP with PTX BSP to be able to boot mini210s over TFTP with Reggie's barebox version. Can somebody advise me please ? Thank you.
