Buildroot for NanoPC-T1
bluscape
Anybody here using buildroot that can assist me we a few minor problems?
I'm trying to configure barebox using make barebox-menuconfig but get an
error:
cp: cannot stat
‘/home/jdoe/local/buildroot/output/build/barebox-2014.08.0/arch/arm/configs/_def
config’:
No such file or directory
Clearly barebox requires a configuration file but I'm not sure what I
should give it.
fatalsaint
I have not tried to build barebox, so this is all conjecture, but I *think*
it's looking for the defconfig for a selected board.  My guess is the Nano
doesn't have a default board name, and this should only get that if
BR2_TARGET_BAREBOX_USE_DEFCONFIG is selected with an empty board name?
Did you cd into:
And look to see what boards it has a defconfig for?  Maybe you can find one
close enough to select that when you do the make menuconfig.
