Has anyone been able to TFTP from a Linux PC to the mini2440? Thought it would be good idea to check this out BEFORE using u-boot to upgrade the kernel. I can FTP files from my Linux box running Kubuntu 9.04 to the mini2440, but only get timed out messages (on the Linux PC) using tftp. I have been through quite a few "how to help sheets" on setting up the TFTP server on the Linux box, but never get a response from the mini2440. Also, if I try to tftpd from the mini2440 all I get is <Connection refused>. I am more interested in being able to tftp files TO the mini2440. Appreciate any pointers. Tnx
TFTP to the mini2440
Yes, that's how I normally download applications during development. I had the same problem initially. The last obstacle was configuring the firewall on the PC (Fedora 11) to allow it.
Hi davef, Linux box should be fined with TFTP. In case your host is behind the router, you need to open the port 21 with your local ip address. Thanks, puma
puma, Thanks for the hint, however after another evening trying to get it to work I realised that I can't even transfer files on the Linux PC . . . from one directory to another! I had to install the TFTP server following this: http://www.davidsudjiman.info/2006/03/27/installing-and-setting-tftpd-in... and then found this to test it: http://book.opensourceproject.org.cn/embedded/addembed/opensource/ch04le... I am using a ADSL router in the system and when I get things to that stage I will check out your suggestion. Cheers
To save someone the time. After installing the TFTP server on the Linux box as found in the 1st link above, put the files to transfer in /tftpboot on the Linux PC (192.168.1.3). Test it as described in the 2nd link. To GET a file at the FriendlyArm from the Linux PC: from root # tftp –l my_tmp/test.txt –r test.txt –g 192.168.1.3 (my_tmp is a directory that you put on the FriendlyArm with chmod 777) To PUT a file from the FriendlyArm to the Linux PC: from root # tftp –l my_tmp/test.txt –r test.txt –p 192.168.1.3 The syntax is not that clear on tftp in the BusyBox commands docs, well it wasn't to me. Now I think the reason I can't tftp from the Linux box to the FriendlyArm is because there is no TFTP (client?) running on the FriendlyArm after boot-up. I see a clue in the usage for tftpd if you just type in tftpd without any options.
You won't be able to initiate a TFTP transfer from the PC side unless you have a TFTP server (TFTPD) running on the FriendlyARM
hi davef, You don't have to install a tftp server on mini2440 since it has already an ftp pre-installed. I recommend to use FileZilla client Linux and everything would be fine for you. I've been using it to my Ubuntu 8.04. thanks, puma
puma and paulw, Thanks both of you for the hints. I can FTP fine to the mini2440. Being able to TFTP was part of a self-imposed learning experience before launching myself headlong into u-boot and kernel compiling territory. There is a line which I believe needs to go into inetd.conf . . . 69 dgram udp nowait root tftpd tftpd files/to/serve which I am about to try. Then u-boot here we come. Cheers, davef
Reading inetd(8) man pages I made a directory in root called <files> in /etc/inetd.conf I added tftp dgram udp nowait root /usr/bin/tftpd /usr/bin/tftpd /files Go to the Linux PC and in my tftpboot directory, where I have a file <test>: tftp 192.168.1.230 tftp> put test Error code 0: malformed packet A search on Google shows up 4 threads for this error, none of which helped. I tried <69> for the initial field entry as per the line you see when you type tftpd in with no options in terminal (on the FriendlyArm). One more hint :) Tnx
Don't bother with further suggestions. Installed WireShark on the Linux PC and proved that the tftp client doesn't even send out anything to the FriendlyArm.
Give this a go, there could errors.
Installing TFTP on the Linux PC running Ubuntu 9.04
The tftp server starts with xinetd on the Linux PC.
The tftp client start when you do tftp
1. Install tftpd and related packages.
$ sudo apt-get install xinetd tftpd tftp
2. Create /etc/xinetd.d/tftp and put this entry:
service tftp
protocol = udp
port = 69
socket_type = dgram
wait = yes
user = nobody
server = /usr/sbin/in.tftpd
server_args = -s /tftpboot
disable = no
3. Make /tftpboot directory in root
$ sudo mkdir /tftpboot
$ sudo chmod -R 777 /tftpboot
$ sudo chown -R nobody /tftpboot
4. Re-start tftpd through xinetd
$ sudo /etc/init.d/xinetd restart
5. Testing. Transfer a file test from 192.168.1.3 (Client using tftp) to
192.168.1.3 (Server 192.168.1.3).
$ chmod 777 /tftpboot/test
6. Create a temp directory, chmod and cd to it.
$ sudo mkdir /temp
$ sudo chmod -R 777 /temp
cd temp
7. Get a file from /tftpboot while in /temp on 192.168.1.3
$ tftp 192.168.1.3
tftp> get test
Received 22 bytes in 0.0 seconds
tftp> quit
8. Put a file in /temp to /tftpboot on 192.168.1.3
$ tftp 192.168.1.3
tftp> put tftpboot_test
Received 34 bytes in 0.0 seconds
tftp> quit
9. Can’t put or get files at the Linux box from/to the FriendlyArm
(see comments above in this thread)
from www # tftp -l dave.txt –r hda.txt –g 192.168.1.3
from root # tftp –l www/dave.txt –r hda.txt –g 192.168.1.3
from www # tftp –l index.html –r index.html –p 192.168.1.3
from root # tftp –l www/index.html –r index.html –p 192.168.1.3
In order to have a tftpd client running on boot-up in /etc/inetd.conf I
added the line:
Hai davef Thank you for your post. This helped me out tranfer files to ARM. I need to develope a Gui App using Qutopia. Could you please share how to setup Qutopia on my ubuntu 9.04. Please kindly share steps to do so
Haven't done that, so can not offer any advice. I assume you have read the other Qtopia threads on this site. Start another thread if none of them fits your needs.
Hello Davef I am trying to communicate to my mini2440 through the FTP and for that I installed the tftp on my Linux Ubuntu 10.04 lucid . I have done upto the installing and creating those directories and files . But when it comes to the testing of my FTP I am not able to that , because I am not clear of few things actually like: 1.As you said in the testing portion "Testing. Transfer a file test from 192.168.1.3 (Client using tftp) to 192.168.1.3 (Server 192.168.1.3)." here you have used the same IP for both the server and the client , so why is this so. 2. the ip address of my mini is 192.168.1.230 so how should I proceed in this direction. Thank you
Piyush, This is almost one year ago and don't think ever used it after I got most of it working! Looks like it should be: Testing. Transfer a file test from 192.168.1.230 (Client using tftp) to 192.168.1.3 (Server 192.168.1.3). 192.168.1.3 was the static address for the Linux host or server. I did have problems, most likely due to my poor understanding of the whole client server setup. Good luck
Hello Davef Have you used the nfs service to transfer the files from your PC to the mini2440. Please give me some help on it that how I can transfer the files from the Linux PC to the mini2440 through the nfs protocol. If you have some blog or document on it ..please do share with me. Thank you
Hi all, i have successfully port u-boot, and its working fine with the jffs filesystem, but i unable to transfer a file using ftp, tftp, and i even i followed the above procedure to transfer file, one more thing my SDCARD is not getting detecting, otherwise i would have copy from it to the fs. can any body give me the solutions for the above two problem, i have created a file called /etc/inetd.conf, and the contents are tftp dgram udp nowait root /usr/bin/tftpd /usr/bin/tftpd /files if i transfer a file from linux pc to friendly arm i got this error /tftpboot# tftp 192.168.1.230 tftp> put file.txt Transfer timed out. if i try to get file from linux pc to friendly arm, i got this error [root@(none) /files]# tftp -l file.txt -r file.txt -g 192.168.1.3 tftp: server error: (0) Undefined error code can any one help me please, waiting for your reply
Did you run a TFTP server on your Mini2440 when you tried to transfer a file from your host (Linux PC) to the Mini2440? (the "put file.txt" case) Is your network up and running and configured correctly at both sides (host and Mini2440)? Did you see the accesses from the Mini2440 in the logfiles at your host (Linux PC)?
MINI2440# tftp 0×31000000 uImage dm9000 i/o: 0×20000300, id: 0x90000a46 DM9000 : running in 16 bit mode MAC:08:08:11:18:12:27 TFTP from server 10.0.0.1; our IP address is 10.0.0.2 Filename ‘uImage’. > > Load address: 0×31000000 > > Loading: T T T T T T T T T T > > Retry count exceeded; starting again thanks for your reply
Hi, Same problem here... As I run ubuntu in a virtual machine, I used tftp32 on my windows machine. Now it works. I have to say i am complete newbie in linux ... Luc
ashen:how to use atftpd, means the command to transfer the kernel image is same or different. If you know any document or website then please inform me.
Hi, I am working on mini2440 board.I have successfully ported 3.16 kernel on the board.How do you transfer files to FriendlyARM board?I have installed tftp server on my HOST(ubuntu) machine.tftp client need to run on the board? When i typed tftp in my board ,its says command not found. Pls help me. Regards, Sudhakar.G
Assume you are using Busybox. On the command line, on the target, type: busybox Copy and paste the result in your reply.
Hi davef,
root@mini2440:/ busybox
BusyBox v1.22.1 (2015-02-13 14:38:59 IST) multi-call binary.
BusyBox is copyrighted by many authors between 1998-2012.
Licensed under GPLv2. See source distribution for detailed
copyright notices.
Usage: busybox [function [arguments]...]
or: busybox --list
or: function [arguments]...
BusyBox is a multi-call binary that combines many common Unix
utilities into a single executable. Most people will create a
link to busybox for each function they wish to use and BusyBox
will act like whatever it was invoked as.
Currently defined functions:
[, [[, addgroup, adduser, ar, ash, awk, basename, bunzip2, bzcat,
cal, cat, chgrp, chmod, chown,
chroot, clear, cmp, cp, cpio, cttyhack, cut, date, delgroup,
deluser, df, dirname, dmesg,
dnsdomainname, du, dumpkmap, echo, egrep, env, expr, false, fdisk,
fgrep, find, free, fsck,
fsck.minix, ftpget, ftpput, getty, grep, gunzip, gzip, halt,
hexdump, hostname, hwclock,
ifconfig, ifdown, ifup, init, insmod, kill, killall, klogd, less,
ln, loadfont, loadkmap, logger,
login, ls, lsmod, md5sum, mesg, mkdir, mkfifo, mknod, mktemp,
modprobe, mv, netstat, nice, nohup,
nslookup, od, passwd, pidof, ping, poweroff, printenv, printf, pwd,
readahead, readlink,
realpath, reboot, renice, reset, resize, rm, rmdir, rmmod, route,
run-parts, sed, seq,
setconsole, setkeycodes, sh, sleep, sort, start-stop-daemon, stat,
stty, su, sulogin, sum, sync,
tail, tar, tee, telnet, telnetd, test, touch, traceroute, true,
tty, uname, uncompress, uniq,
unxz, unzip, uptime, usleep, uudecode, uuencode, vi, watch,
watchdog, wc, which, who, whoami,
xargs, xz, xzcat, yes, zcat
root@mini2440:/
Regards,
Sudhakar.G
You could enable tftp in Busybox and re-compile. Just want to check that you are NOT using the Pengutronix BSP and have ported your kernel and root filesystem from scratch.
Hi davef,
I have used Pengutronix BSP to port my kernel & root filesystem in
mini2440.
Regards,
Sudhakar.G
I was confused by: I have successfully ported 3.16 kernel on the board. Do you mean you enabled Pengutronix to use the 3.16 kernel etc. To get tftp in ptxdist menuconfig search for tftp and navigate your way to the appropriate page in menuconfig and enable it.
Hi davef,
Yes i have enabled Pengutronix to use the 3.16 kernel.
Thank you for your help .I will do that.
Regards,
Sudhakar.G
Hi davef,
By using Pengutronix BSP for mini2440 ,i was able to build 3.16
kernel image,root filesytem ,barebox-image and i have used Nand flash
memory i.e 6.2 in user manual to tranfer the files to Friendlyarm board.
Here i am facing 2 problems.
1--> LCD is not working ..AM using W35 panel.If i want to make LCD to work
what changes / files i need to edit.
2-->How should i transfer the files from HOST to Friendly arm board.
I tried with tftp command in the Target ,it says command not found.
As you said i went to the ptxdist menuconfig .. i have enabled tftp .
But no result .
Regards,
sudhakar.G
The w35i LCD is supported by the Pengutronix BSP. So, if yours is really not a w35i then you need to search this forum and http://blog.gmane.org/gmane.comp.embedded.ptxdist.oselas.community to see if someone else has had this problem If yours is really a w35i then Section 4.2.3 These features can be enabled/disabled or configured at run-time with the kernel parameter mini2440=. The content of this parameter is also configured in the config files mentioned above. I use the N35, which must be the default LCD because I never had to change anything. It appears that a previous config file needs changing to: mini2440=w35i I guess it refers to: configs/platform-friendlyarm-mini2440/barebox-64m-env/config or 128m depending on the flash size. tftp Have you verified that your tftp client is now working on the target? You did re-compile the root filesystem after enabling it?
Or you can edit this file at runtime. On page 27 you will see a command: mini2440:/ edit /env/config (after you Hit any key to stop autoboot) then at; bootargs="........ mini2440=[the number of your display]tbc This only applies after you sort out your w35 or w35i uncertainty.
Hi davef,
I am using LCD W35 panel .I did the same thing ..as you said .I
edit the file /env/config and i have given
bootargs=".......mini2440=[6tbc] becoz 6 is the no.for w35i panel as
mention in the manual ..
But the LCD is not working ..After booting the target board ..I was able to
see white screen.
Is w35 & W35i lcds are differnt?
Regards,
Sudhakar.G
http://search.gmane.org/?query=w35i&group=gmane.comp.embedded.ptxdis... as per my link above. And have you searched this forum for w35i, there are 2 pages of hits.
Hi davef, I am using w35i , now i have checked back of LCD display it is written as w35i : 3.5” TFT + touchscreen (LQ035Q1DG06) I have edited the same file mini2440:/ edit /env/config bootargs="............mini2440=6bt"; [6 is the number i need to pass i am selecting w35i ] as mentioned in manual. But still i didn't get the LCD display. Regards, Sudhakar.G
To check you will need to get minicom running on your host and connect the RS232 cable up so that you can look at the boot messages. Firstly, you want to confirm that you see a line: MINI2440: LCD 0:240x320 1:800x480 2:1024x768 3:240x320 4:640x480 5:240x320 [6:320x240] 7:480x272 Note the square brackets around your LCD selection. Secondly, can I assume you have read through the info at the link I included and you search for clues on this forum.
No, try this for secondly.
Have you enabled virtual terminal in the kernel?
$ ptxdist kernelconfig
Device Drivers --->
Character devices --->
[*] Virtual terminal
[*] Enable character translations in console
[*] Support for console on virtual terminal
Graphics support --->
[*] Support for frame buffer devices --->
<*> S3C2410 LCD framebuffer support
Console display driver support --->
<*> Framebuffer Console support
[*] Map the console to the primary display device
[*] Select compiled-in fonts
[*] VGA 8x8 font
Things might be slightly different as this was for kernel 3.7
Re-compile kernel and tell us what you see.
Hi davef, THis is the output i got from the boot messages ... MINI2440: Option string mini2440=6tb MINI2440: LCD 0:240x320 1:800x480 2:1024x768 3:240x320 4:640x480 5:240x320 [6:320x240] 7:480x272 second thing ---> I have re-compiled the kernel by enabling all the options what you have mentioned .After booting my board ..on the LCD at one of the corner cursor is blinking ... on the Target Board , i have given these commands root@mini2440:~ ts_calibrate xres = 320, yres = 240 Took 3 samples... Top left : X = 777 Y = 319 Took 1 samples... Top right : X = 48 Y = 543 Took 1 samples... Bot right : X = 18 Y = 548 Took 7 samples... Bot left : X = 745 Y = 648 Took 2 samples... Center : X = 455 Y = 624 282.489258 -0.300107 0.000250 -82.975342 0.022592 0.361192 Calibration constants: 18513216 -19667 16 -5437872 1480 23671 65536 root@mini2440:~ts_test root@mini2440:~ fbtest Using drawops cfb16 (16 bpp packed pixels) Available visuals: Monochrome Grayscale 32 Truecolor 5:6:5:0 Using visops truecolor Running all tests test001: PASSED test002: PASSED test004: PASSED test006: PASSED test008: PASSED test009: PASSED oot@mini2440:~ cat /proc/cmdline console=ttySAC0,115200 mini2440=6tb ip=192.168.0.230:192.168.0.147:192.168.0.2:255.255.255.0::: root=/dev But LCD display is not working . Regards, Sudhakar.G
Looks like good progress. For the third time ... the link and a search on the forum did not help with your issue? You need to answer my questions, and then I will stop asking them. I will be back in about 2-3 hours for your reply.
Can you please answer my question? You need to learn how to search for answers. You can be quite sure someone has possibly had this problem before and "told the world about it" on some forum, somewhere. I haven't got the answer for you I am only trying to help.
There are two LCD units out there: "w35" and "w35i". "w35 with analogue touchscreen and GPIO controlled backlight and "w35i" with onewire touchscreen and onewire backlight control.
dear all
help me how to install images to mini2440(W35) from ubuntu host
i followed the manual am getting this error
Enter your selection: q
Supervivi> load ram 0x31000000 154048 u
Now, Downloading [ADDRESS:31000000h,TOTAL:154058]
RECEIVED FILE SIZE: 154058 (150KB/S, 1S)
Downloaded file at 0x31000000, size = 154048 bytes
Supervivi> go 0x31000000
go to 0x31000000
argument 0 = 0x00000000
argument 1 = 0x00000000
argument 2 = 0x00000000
argument 3 = 0x00000000
barebox 2011.05.0-ptx-2014.11.0 (Feb 13 2015 - 14:44:10)
Board: Mini 2440
NAND device: Manufacturer ID: 0xec, Chip ID: 0xd3 (Samsung NAND 1GiB 3,3V
8-bit)
Bad block table not found for chip 0
Scanning device for bad blocks
Bad block table written to 0x3ffe0000, version 0x01
Bad block table written to 0x3ffc0000, version 0x01
dm9000 i/o: 0x20000300, id: 0x90000a46
eth@eth0: got MAC address from EEPROM: 00:00:00:00:00:00
cfi_probe: cfi_flash base: 0x00000000 size: 0x00200000
refclk: 12000 kHz
mpll: 405000 kHz
upll: 48000 kHz
fclk: 405000 kHz
hclk: 101250 kHz
pclk: 50625 kHz
SDRAM1: CL4@101MHz
SDRAM2: CL4@101MHz
Malloc space: 0x33a00000 -> 0x33e00000 (size 4 MB)
Stack space : 0x339f8000 -> 0x33a00000 (size 32 kB)
envfs: wrong magic on /dev/env0
no valid environment found on /dev/env0. Using default environment
running /env/bin/init...
mini2440:/ devinfo eth0
base : 0x00000000
driver: none
Parameters:
ipaddr = 192.168.0.230
ethaddr = 00:1c:c0:0f:cd:aa
gateway = 192.168.0.2
netmask = 255.255.255.0
serverip = 192.168.0.147
mini2440:/ dhcp
phy0: Link is up - 100/Full
T DHCP client bound to address 192.168.0.37
mini2440:/ saveenv
saving environment
mini2440:/ ./env/config
mini2440:/ ping 192.168.0.7
T host 192.168.0.7 is alive
mini2440:/ update -t barebox -d nand
T host 192.168.0.147 is alive
erasing partition /dev/nand0.barebox.bb
flashing barebox-mini2440 to /dev/nand0.barebox.bb
TFTP from server 192.168.0.147 ('barebox-mini2440' ->
'/dev/nand0.barebox.bb')
thanks in advance
Specifically which error? You mean nothing happens after:
While connecting to the mini2440 with ftp, I am getting as follows. Connected to 172.16.4.122. 220 FriendlyARM FTP server (Version 6.4/OpenBSD/Linux-ftpd-0.17) ready. Name (172.16.4.122:mou): plg 331 Password required for plg. Password: 230 User plg logged in. Remote system type is UNIX. Using binary mode to transfer files. ftp> bin 200 Type set to I. ftp> put hello local: hello remote: hello 200 PORT command successful. 553 hello: Permission denied. Can anyone suggest what may be the reason?? Thanks in advance.
I have Same Error Connected to 192.168.1.230 220 FriendlyARM FTP server (Version 6.4/OpenBSD/Linux-ftpd-0.17) ready. Name (192.168.1.230:Soma): plg 331 Password required for plg. Password: 230 User plg logged in. Remote system type is UNIX. Using binary mode to transfer files. ftp> bin 200 Type set to I. ftp> put hello local: hello remote: hello 200 PORT command successful. 553 hello: Permission denied. Pls Help Me...
