Hi fellas, Here I am in front of you with an outstanding problem again :) I am trying to use the usbpush as it described but unfortunately its giving an error like "Unable to claim usb interface 1 of device: could not claim interface 0:Operation Not Permitted" So I would like to know if any of you has got a problem like this. Also when I try to re-build the binary, usb.h is missing, I found some usb.h files on dvd but not sure which one is suitable. Any Ideas how to solve this problem?? and also is there any other way to update the NOR without J-TAG ?? For supervivi
USB-Push
hm, let's see the first problem. eduardo@eduardo-desktop:/opt/FriendlyARM/mini2440/linux-2.6.29/arch/arm/boot$ usbarmpush zImage Unable to claim usb interface 1 of device: could not claim interface 0: Operation not permitted Oh, seems like the same error that you posted... but TRYING TO EXECUTE AS ROOT: eduardo@eduardo-desktop:/opt/FriendlyARM/mini2440/linux-2.6.29/arch/arm/boot$ sudo usbarmpush zImage [sudo] password for eduardo: csum = 0x804e send_file: addr = 0x30000000, len = 0x001f63ac it work's!! u.u try out and tell us your result!! the second problem: i'm trying to know how to use j-tag. xD regards ps: usbarmpush is a link that i created for usbpush program.
OOps I knew I am missing something really stupid.. But it is normal after working in front of pc for 8 hours in a row. Thanx in anyway dude.. apriciated!
Hi Guys !! I got the same error than deha : "Unable to claim usb interface 1 of device: could not claim interface 0:Operation Not Permitted" I've tried what eduardo said : sudo usbpush u-boot.bin But unfortunetly I got the message : "sudo: usbpush: command not found I am using ubuntu 10.10 Thanks Everybody, Jeremy
I found it was a silly question. I just add the path of usbpush sudo .../usbpush/usbpush/ u-boot.bin Have a nice day
you can give a link just like below where did you download the usbpush, give correct directory #ln -s ../usbpush/usbpush/usbpush /usr/bin/usbpush you can use directly usbpush command at now.
