Tiny 210 - Pen drive is not mounting - USB drive issue - Help !!
rajathithan
I need to mount the pen drive in Tiny 210, after i inserted the pen drive ,
i clicked on the app "usb storage". It gave out a message as "USB storage
is not mountable". Please let me know how to mount this pen drive.
I also dont know how to SSH to this device, any instructions related to
this would be of great help.
rajathithan
Error message that am getting :
<6>[  672.697078] usb 1-1: new high speed USB device number 6 using
s5p-ehci
<3>[  672.818143] usb 1-1: device descriptor read/64, error -71
<3>[  673.044718] usb 1-1: device descriptor read/64, error -71
<6>[  673.259552] usb 1-1: new high speed USB device number 7 using
s5p-ehci
<3>[  673.380635] usb 1-1: device descriptor read/64, error -71
<3>[  673.607216] usb 1-1: device descriptor read/64, error -71
<6>[  673.822049] usb 1-1: new high speed USB device number 8 using
s5p-ehci
<3>[  674.243910] usb 1-1: device not accepting address 8, error -71
<6>[  674.353302] usb 1-1: new high speed USB device number 9 using
s5p-ehci
<3>[  674.775179] usb 1-1: device not accepting address 9, error -71
<3>[  674.775270] hub 1-0:1.0: unable to enumerate USB device on port 1
<6>[  675.161899] usb 2-1: new full speed USB device number 3 using
s5p-ohci
<6>[  675.309238] usb 2-1: not running at top speed; connect to a high
speed hub
<6>[  675.322823] scsi1 : usb-storage 2-1:1.0
<5>[  677.208344] scsi 1:0:0:0: Direct-Access     SMI      USB DISK
1100 PQ: 0 ANSI: 4
<5>[  677.213870] sd 1:0:0:0: Attached scsi generic sg0 type 0
<5>[  677.221274] sd 1:0:0:0: [sda] 15994880 512-byte logical blocks: (8.18
GB/7.62 GiB)
<5>[  677.227332] sd 1:0:0:0: [sda] Write Protect is off
<7>[  677.227385] sd 1:0:0:0: [sda] Mode Sense: 43 00 00 00
<3>[  677.233382] sd 1:0:0:0: [sda] No Caching mode page present
<3>[  677.233435] sd 1:0:0:0: [sda] Assuming drive cache: write through
<3>[  677.266257] sd 1:0:0:0: [sda] No Caching mode page present
<3>[  677.266309] sd 1:0:0:0: [sda] Assuming drive cache: write through
<6>[  677.275404]  sda: sda1
<3>[  677.305259] sd 1:0:0:0: [sda] No Caching mode page present
<3>[  677.305313] sd 1:0:0:0: [sda] Assuming drive cache: write through
<5>[  677.305366] sd 1:0:0:0: [sda] Attached SCSI removable disk
