Alternative download link for ubuntu_nanopc_t1_sd_8g.img ?
Rico da Halvarez
Hi there,
I'm Rico da Halvarez, french net-artist (http://vnatrc.net)
I intend to use the nanopc T1 to broadcast my digital works
I received today a nanopc, but it was configured under android, while I'm
working under ubuntu.
So I wanted to download ubuntu_nanopc_t1_sd_8g.img but impossible, the
server does not...
Are there an alternate address to download this system image? Why don't you
use bittorent in alternative link?
Thanks in advance for your answers ;-)
RdH
Rico da Halvarez
This URL is down: 112.124.9.243
MIN MIN THEIN
I am Min Min Thein, working for DNR Process solution and I am working on
the project to monitor AED device using FriendlyArm nanoPC which I bought
through Aliexpress website and it didn't come with Ubuntu disk image and I
try to find online but link is broken at the moment.
Please help me to send the alternative website to download the ubuntu.
Your faithfully,
Min Min Thein
lsk
I googled it. So ,not sure it'll work.
http://pan.baidu.com/s/1sjNgenF#dir/path=%2FFriendlyARM%20works%2FT1%2Fu...
Beware Baidu's, check what you've downloaded.
Or wait for the others come with their image.
Rico da Halvarez
Thanks, I had also found these images. But there are three .img files, then
which install? In addition, the zip is corrupted. Too bad that there be
only one place where you can download this ubuntu...
Rico da Halvarez
Okay, I launched a wget command, and the server responded. But it is
horribly slow (around 10kb/s)
As soon as I would have recovered the file (2 days), I will share/seed it
on BitTorrent.
Are there an friendlyarm admin here? On what kind of server do you store
the ubuntu image?
Rico da Halvarez
Download stopped at 7% of the file. The server is again unavailable...
Could you do something about it please?
Rico da Halvarez
OK, after intense googlbinging:
http://forum.nanopc.org/viewtopic.php?f=3&t=851 -> list of images available
http://wk.mems-lab.com/nanopc/ubuntu_sd_nanopc_t1.zip -> easyly
downloadable archive
http://www.geeetech.com/wiki/index.php/NanoPC -> tutorial
Tommi Uitto
http://pan.baidu.com/wap/link?uk=3590650401&shareid=3678411295&t...
