Tiny6410 not boot from NAND after install from SD card
tiensu
Hi you!
I installed OS(Linux, Android, WinCE) from SD card for tiny6410 board. It
done(copy 100%). I switch mode to boot from NAND but not success. On LCD
display: "FrendlyARM Enhanced calibration utility. Touch crosshair to
calibrate. TouchDevice: /dev/touchscreen-1wire".
I don't know how to fix this problem. Can anybody help me? Thanks you very
much!
tiensu
This is file FriendlyARM.ini:
LCD-Mode = Yes
LCD-Type = S70
CheckOneButton=No
Action=install
OS=Android
VerifyNandWrite=No
StatusType = Beeper| LED
################### Android ####################
Android-BootLoader = superboot-6410.bin
Android-Kernel = Android/azImage_s70
Android-CommandLine = root=ubi0:FriendlyARM-root ubi.mtd=2 rootfstype=ubifs
 init=/linuxrc console=ttySAC0,115200 androidboot.console=s3c2410_serial0
Android-RootFs-InstallImage = Android/rootfs_android-mlc2.ubi
Android-RootFs-RunImage = Android/rootfs_android.ext3
lsk
Isn't that calibrator program??
Just touch + symbol..
tiensu
I touched + symbol, it can move around LCD but nothing happen. Please help
me!
lsk
You have to touch at it right 5 positions, if you touch fail even 1 mm it
will let you touch it again and again.
tiensu
I will try on. Thanks you!
tiensu
Hi Isk, what are 5 positions which you say? Are they right top conner, left
top conner, right bottom conner, left bottom conner and center?
tiensu
Hi Isk, what are 5 positions which you say? Are they right top corner, left
top corner, right bottom corner, left bottom corner and center?
lsk
Yes they're, isn't it finished after you calibrate it ?
tiensu
Currently, I am not ready to do it. I will do in the this evening. I hope
receive your help if have any problem. Thanks you very much!
tiensu
Hi Isk, my problem solved. Thanks you very much!
lsk
Good to hear that.
Btw, it's LSK ><"
