One wire touchscreen on mini2440
Ajit
How to you "TouchDevice:/dev/touchscreen-1wire" on mini2440??
When I Run my application touchscreen doesnt responce.
I use export QWS_MOUSE_PROTO="tslib:/dev/touchscreen-1wire
Intellimouse:/dev/input/mice"
Mouse works fine.
I reffered http://www.friendlyarm.net/forum/topic/5609 this topics last
part for one wire touchscreen.
Any Help??
Ajit
SOLVED
la_glutte
I ported 6410 one_wire_touchscreen driver to 2440, it works very fine, is
Friendlyarm OK to give it? or mini2440_ts_drv.ko ?
Abhi11
Hi Ajit,
I am facing the issue what you faced.Can you share the solution.
Regards
Abhi
Abhishek Ekhare
Hi Ajit,
I am facing the same problem. I referred
http://www.friendlyarm.net/forum/topic/5609.
Will you please share your solution.
Ajit
From http://www.friendlyarm.net/forum/topic/5609
Go to friendly arm forum given at end of following link
http://www.friendlyarm.net/downloads
go to /src
file name: one-wire-ts-input-src-20111026.tar.gz
an open source tslib for FriendlyARM one wire touch screen, only for Linux,
not Android
How to use
by FriendlyARM, 2011-10-26
step1: unzip the source code tarball
    #make
   you will get one-wire-ts-input.so, put it into the tiny6410
board: /usr/lib/ts/
Step2:
   vertify the first line in file "/etc/ts.conf"  to:
   module_raw one-wire-ts-input
5. Run Qt example program:
Now we can test Qt example programs
$cd /mnt/demos/embedded/fluidlauncher/
$./fluidlauncher -qws
use touch now :-)
